Transmission flush question / concern...
Old 04-24-2008, 09:06 AM
ccundiff12's Avatar
Ok today i set out to change my transmission fluid and filter. (94 runner 3.0 4x4 auto) I cracked open the line at the transmission cooler like the guy at the auto shop said. no matter if the truck is running or not I only got a few drips of fluid to come out. the fluid looked NEW, bright red and thick. so not being able to get anything out here i went to open the transmission pan drain. the fluid here was thin and black. (i knew it needed changed) so should i be concerned that the fluid in these two locations is drastically different, and if so how should i proceed? Thus far all i have done is drain about 4qts out of the pan.
Old 04-24-2008, 04:39 PM
mr toytech's Avatar
sounds like you have a glogged line in the trans cooler. yes it is a concern. your fluid is not getting cooled properly.
Old 04-25-2008, 09:20 AM
ccundiff12's Avatar
big mistake, please help
The pan that I pulled was the rear transmission pan, 11 bolts. There is an auxiliary cooler beneath the frame which is what I drained. My question is does this rear pan fill when you fill the transmission or is there a separate fill for the rear pan?
Old 04-25-2008, 10:33 AM
mt_goat's Avatar
This should answer a lot of your questions about refilling: https://www.yotatech.com/forums/f116/a340h-fluid-86460/
Here's the main point if you don't want to read the whole thread:
https://www.yotatech.com/50654038-post16.html
Old 04-25-2008, 10:48 AM
ccundiff12's Avatar
Thank you so much!! That was exactly what I needed to know!
Old 04-25-2008, 11:28 AM
mt_goat's Avatar
No problem, good luck with that black ATF problem though. Sounds bad
Old 04-27-2008, 05:55 AM
ccundiff12's Avatar
Well after an entire day of work that should have taken two hours... everything is finally back together. (as it turns out it's a bitch to remove the transfer case pan) Actually my tranny seems to be preforming much better after the flush. The only other question i have is, does anyone else have any trouble reading the transmission dipstick on these model trucks? I'm pretty sure that for every one quart out i put one back in, but when i go to read the dipstick it isn't all that clear where the fluid actually stops.
Old 04-27-2008, 06:38 AM
mt_goat's Avatar
Check this out, different tranny but same info applies as to reading the dip stick and checking the level:
https://www.yotatech.com/forums/f2/a...pacity-143365/
the1998sr5
15
07-14-2020 08:35 PM
chuckross1957
06-28-2019 10:19 PM
mYnAmEiSmUd
07-20-2015 06:48 AM
jjrbus
07-19-2015 02:06 PM
jjrbus
07-17-2015 07:06 AM
Quick Reply: Transmission flush question / concern...
