transmission dipstick?
Old 08-25-2007, 07:24 AM
monst's Avatar
where on the 3vze manual is the transmission dipstick?
Old 08-25-2007, 07:31 AM
CJM
CJM's Avatar
Manual gear boxes dont have trans dipsticks. You can check the fluid under the truck in the trans fill hole.
Old 08-25-2007, 07:45 AM
monst's Avatar
I want to put synthetic transmission oil in, is there a recommend brand/type for the 3vze?
Old 08-25-2007, 08:46 AM
MMA_Alex's Avatar
which trans is it?
on my w56 (on the 22re) i've had luck with redline mt-90
Old 08-26-2007, 08:36 AM
monst's Avatar
not sure what transmission
1995 manual 3.0 4runner.
Old 08-26-2007, 08:48 AM
eric-the-red's Avatar
Probably a R150. The synchros in those don't like GL-5 fluid, stick to a GL-4 type. Like MMA_Alex said Redline MT-90 works well.
Old 08-26-2007, 09:19 AM
drew303's Avatar
I've yet to find GL-4 gear oil, anywhere...
They say meets GL-5 or meets and exceeds GL-4, GL-5 blah blah
or they say GL3 GL4 GL5 and nothing else
can anyone explain wtf is the difference between all the GL's or is this just a SAE quality rating? whats the deal?
my G54 loves this mobil 1 75w-90 tho
Old 08-26-2007, 11:00 AM
MMA_Alex's Avatar
gl-5 is a high pressure gear oil which has additives that tend to eat away at brass. i believe the syncros in these transmissions are made of brass.
Old 08-26-2007, 12:11 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Good, good thread here:
https://www.yotatech.com/forums/f116...uestion-98830/
Old 08-26-2007, 02:13 PM
pennywize's Avatar
i love redline mt90. locally shops around here dont stock it, i always have to special order it. they usually stock redline mtl but i like the mt90. made my old rx7 shift waaaay better. im gonna put it in my w56 soon.
Old 08-26-2007, 02:36 PM
UKMyers's Avatar
That little book in your glove compartment is full of absolutely amazing facts!!! Put some Redline MT-90 in there and call it good. You'll be amazed! Oh ya I'm gonna put your post in my sig line that's a classic one!!
Old 08-27-2007, 04:55 AM
monst's Avatar
I knew i would have a famous quote one day. Anyways ill pickup some Redline MT-90. How much do I need?
Old 08-27-2007, 05:38 AM
ewong's Avatar
read the owners manual - its spec'd there.
Off the cuff - about 4qts? maybe 5?
Also - xfer case too...
Old 08-27-2007, 02:46 PM
thook's Avatar
Some of it also depends on how much of the old oil you can out. Drive it around and get the trans. hot before you drain it. More will come out. And make sure you can get the fill plug off before you drain it.
ToyotaMD
09-22-2015 06:28 AM
briholt
09-20-2015 10:26 PM
TransAmBandit
09-20-2015 06:08 PM
viesail
09-05-2015 04:23 AM
kelly1450
09-02-2015 12:29 PM
Quick Reply: transmission dipstick?
