transmission or clutch problems
Old 03-23-2009, 05:29 PM
j0hNnI's Avatar
whats up i got a 89 yoda 3vz 6 banger 4wheeler of course
anyways bought the truck from some guy and ive had to double clutch going into fourth an i was driving home from subway today about a half a block away from my place of residence i brought it out of fourth an it wouldnt go into any other gear, i pushed on the stick hard enough to get it into third but it wont go into or out of any gear now, wondering if its the clutch of tranny, an if its the tranny what can be done to fix it thanks
Old 03-23-2009, 05:37 PM
stagger_lee's Avatar
Sounds like the clutch to me.
Old 03-24-2009, 07:06 AM
magnum's Avatar
i had a similar problem with my jetta, that i no longer own. and it turned out to be the throwout bearing.
Old 03-24-2009, 07:12 AM
Marc's Avatar
Check the clutch fluid level. If it's low or empty it could be the slave cylinder.
Old 03-24-2009, 09:29 AM
j0hNnI's Avatar
i got full fluids
it really could be the clutch for some reason my gut says the trannys bad cause its stuck in third i popped it out this morning though but i was pulling so hard i started to shake, now im stuck in neutral but even in neutral the truck moves slightly like the clutch is still touching the plate
Old 03-24-2009, 06:28 PM
j0hNnI's Avatar
Originally Posted by j0hNnI
i got full fluids
yea it was stuck between 3rd an fourth an like a quarter teh way into 3rd i rolled the truck down a hill an popped the clutch an somethin in th etranny popped now i have all my gears again it just grinds into 3rd 4th an 5th if i dont double clutch whats this sound like to everyone?
Old 03-24-2009, 06:53 PM
desconhecido's Avatar
Start with simple possibilities--check the operation of the clutch master and slave cylinders. Is the clutch mechanism on the transmission being activated when you press the pedal down? You'll have plenty of time left to drop the transmission, if necessary.
Old 03-24-2009, 07:08 PM
MSR
MSR's Avatar
the r150 is a tough trans i'd start with clutch or clutch hydralics before condeming the trans
Old 03-24-2009, 07:49 PM
Ed H.'s Avatar
definitely check your slave and master cylinder if one is bad replace both. the other one usually fails shortly after.
Old 03-26-2009, 08:28 PM
j0hNnI's Avatar
i went out to bleed my clutch today to see if tat would help any an when i push my clutch to the floor an open the bleeder the clutch sticks to the floor after i close the bleeder is this whats spose to happen? or is somethin bad cause ive blead clutchs on chevys an they clutch always popped back up not sure about a toyo maybe somethins different
smthwsn357
12-04-2023 02:08 AM
the1998sr5
15
07-14-2020 08:35 PM
mskalmus
05-28-2017 07:51 AM
Poncho0206
07-10-2015 06:21 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: transmission or clutch problems
