Transfer case with electronic speedometer setup swapped into mechanical speedo truck?
Old 01-12-2011, 09:31 AM
wilshire's Avatar
I swapped a 1993 transmission into my 1990 pickup. The transfer case on the new transmission has the electronic vehicle speed sensor on it. My truck has a mechanical speedometer cable. Eventually I want to swap in an electrical speedometer cable and a different gauge cluster, but in the meantime, what's the best way to get my speedometer hooked back up?
Can I swap the speed output parts from old transfer case to the new one?
Old 02-28-2012, 01:45 PM
BlindfoldMemphis's Avatar
Did you ever figure it out?
What did you end up doing?
Old 02-28-2012, 02:09 PM
mt_goat's Avatar
You can just swap the speed sensors to match your cable or wiring and dash cluster. The part the goes into the transfer case is the same on both (except there are different gear ratios). Only the outside is different between the 2.
Old 02-28-2012, 02:46 PM
donomite49's Avatar
@ goat, what is the best way to keep the speedometer cable for the stock gauge and getting the proper vss signal for the a340f trans and computer going in my 88 xtra cab with the stock gear drive transfer case. any ideas?
Old 02-28-2012, 04:29 PM
mt_goat's Avatar
I'm not sure on that one.
Old 02-29-2012, 02:39 AM
wilshire's Avatar
BlindfoldMemphis - I ended up doing MrGoat's suggestion and swapping the sensors. It was a breeze.
Old 02-29-2012, 02:45 AM
racerflea's Avatar
Could that work when converting to a th350 trans??
Old 08-15-2013, 09:43 AM
Bumpin' Yota's Avatar
Red face
Likewise! Id definitely like to know!
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
YotaGreenhorn
06-27-2015 07:00 AM
P51warrior
06-25-2015 05:50 AM
ACZR
06-23-2015 07:55 PM
Quick Reply: Transfer case with electronic speedometer setup swapped into mechanical speedo truck?
