Transfer case brake
Transfer case brake
since i have another truck anyone ever made their own. Using a yota rotor, brake caliper, t fitting tied into the brake line ? just curious if that would work. even you were able to fab a bracket .
If you think about it long enough...you'll realize how bad of an idea it is.
It's too complicated for one thing. And even if you did manage to make it work, it would be WAY heavier than it needs to be, and have WAY more braking power than is required for the purpose. It's kinda like swatting a fly with a sledgehammer.
The t-case brakes you can buy pre-fabbed are the best way to go. Or just copy the idea and make your own.
Just a off the wall idea. after i sat down looking i realized, even if i made the rotor smaller it'd have issues like you just stated. never hurts to get comments though.
yep if only i could have drawn that, only instead of having to replace the unit. replace the pads,like you do with disc brakes. i went with all pro's kit on my 89. just had some thoughts about it that's all. isn't that why we're all here and driving yota's ?
FS[PacSouthWest]: FS: A340 transmission and t/case Lancaster Ca
4x4-runner
12-27-2016 01:58 PM
priest16
15
08-06-2015 07:43 AM
yourrealdad
07-29-2015 11:08 AM
crashburnoveride
07-10-2015 06:39 AM
