| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Transfer case ?
__________________
____________________ Greg 93 4x4 pickup |
#2 (permalink) |
Going from a forwrd shift to a top shift should not require any modifications other the making a block off plate as you mentioned, if you were to got he other direction a new tranny would be needed. It should bolt right in, just be sure to take good measurements on where to drill the new hole in your tunnel. A 3" hole saw works very good for this.
#3 (permalink) |
You can also modify a fdw.shift case to be a top shifter:
- http://www.4x4wire.com/toyota/tech/topshifter/
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#4 (permalink) |
Thanks guys. I have a line on a top shift case with low gears, figured I could swap it in for a while and keep my forward shift in case I decide to do duals. Sounds pretty straight forward.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Transfer case ??? | Lunnzz | 86-95 Trucks & 4Runners | 9 | 12-15-2006 01:00 PM |
| What transfer case do I have? | TRunner | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 07-21-2005 09:31 AM |
| Transfer Case HELP !!! | 4Hummer | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 07-20-2004 06:48 AM |
| how much $$$ for a transfer case? | yotaluver | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 05-31-2004 09:14 PM |
| Transfer case | bayrunner | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 05-05-2004 08:52 PM |
