| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Transfer case ???
__________________
1991 Toyota PU, 4wd, 5spd, 22RE..SOLD 1980 Yota PU LB 4x4 5spd (swap) 20R, weber carb bone stock..Sold 1984 4Runner, 4" lift, 33's and hopefully more to come |
#3 (permalink) |
Pretty sure there's a different spline count on the input shaft on the transfer case for those two. More info here:
http://www.4x4wire.com/toyota/faq/parts/
__________________
94 4runner SR5, V6 3VZE, 5 speed Completely rebuilt engine with Toyota parts at 147k miles Downey Coils, Aisin manual hubs, Cowl Louver mod, Hella 500 fog lights Yeah, I know, not many cool mods here |
#4 (permalink) |
i know there is an adapter to go from a v6 to a 4, but they are different because you cant put 4-1 or 7-1s in a v6 without the conversion because of a chain transfer case opposed to a gear case.
#5 (permalink) |
No it wont work.
More importantly WHY? The 4cyl transfer case is much stronger and far more desirable than the V6 chain drive model.
__________________
1990 Xcab beast of burden 3.0 Rebuild/Precision balanced w/OS valves Custom ported/welded Intake manifolds Downey headers, Jacobs Ign 4" Trail Gear SAS + rear Kit R151 + Dual cases (2.28+4.7) 5.29's,Tru Trac/Lockright on 35 BFG's 140A GM CS144 alt/Hyd assist steering DOA Racing = $1200 lesson in who NOT to deal with |
#6 (permalink) | |
Quote:
The V6 T-case has 0 gear change options. As far as I know the only optional item for a V6 case is a twin stick ($200 from Marlin) There was in the works a not so cost affective dual (4cyl+6cyl) case adapter but I don't think they have finished it yet (posted on the Marlin Boards). The 4cyl T-case has quiet a few options as far as gearing but 4.7 to 1 is the most common (2.28 to 1 is stock). You have Dual case adapters made for the 4cyl T-case. You also have 21 and 23 spline gear sets and input shafts available. There are a few makers of twin stick kits for the 4cyl case (Marlin,Skys,etc...)
__________________
#7 (permalink) |
There is a VF1A that was used on the 3VZ and the 22RE, while the Rf1A?? was used only on the 22Re
__________________
Toyota Master Diagnostic Technician "MDT" 1998 Toyota Tacoma TRD V6 4WD 5 SPD 1998 Chevrolet K1500 1999 Toyota Camry 2003 Toyota Highlander 4WD 2007 KTM 85SX 17/14 2006 KTM 300XC-W 2005 KTM 65SX 2004 Kawasaki KLX 110 2003 Honda XR50 2002 Yamaha TTR 125L 2002 Kawasaki KLR650 2002 Suzuki Eiger 400 4WD 2004 Cargomate<--link GeePaw® Racing<--link |
#8 (permalink) |
I think that's debateable. Marlin indeed now has an adapter to put a crawl box in front of the chain drive case (MC10). Both Marlin and Inchworm have been doing it A LONG TIME with the chain drive Taco cases, holding up to WAY more power than a 22RE or 3VZE will EVER make.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#9 (permalink) | |
Quote:
I cannot find the chain drive dual adapter on marlins site (MC-10 as the R-10 is a 10* gear adapter). I can find the R+D thread started 2004 with the expected price of $649!! for a dual case adapter. here is exactly what marlin has to say about the chain VS gear comparison. # Benefits of a Gear Drive Transfercase: Multiple Housings # Stronger Gears (no chain stretch) # Stronger Bearings # Stronger Case Design # 21- or 23-spline Input Gear # Unbreakable 23-spline input gear # No Oil Pump Required # Fewer Moving Parts # Accepts Marlin Crawler Gears # Accepts Marlin Crawler Dual Cases # Can be located in most recycling yards Benefits of a Chain Drive Transfercase: # Shift into 4WD at speeds up to 50 miles per hour # Weighs Less # Lower Stock Low Range (2.57) Marlins take on the chain VS gear You can tout how much power a chain taco case can take but you put a 4.7 to 1 crawl box in front of it and now you have 22r or 3.0 power multiplied x4.7 and in this case I'm sure the chain case falls short. avg 3.0 makes lets say conservatively 150 ft/lb of Tq? (rated at 180ft/lb's but most are old motors) and yes we are talking about crank HP we have no need for wheel hp on this topic 150x4.7=705 ft/lbs of Torque? Now add the low range of the chain box as well since all gear reduction is done before the power is delivered through the chain to the front drive shaft. 705x2.57=1811 ft/lbs of Torque Granted these numbers are absolutes but in the world of rock crawling and dual cases they usually deal in worst case situations due to lack of better judgment (AKA... Lead Foot syndrome) so In response to "I think that's debateable." I would venture to say its not. Edit... The only reason I can come up with for a taco chain drive case adapter is because of the drivers side T-case output where a gear drive case is not possible. If Toyota had offered a Gear drive case with a driver side output I'm sure there would be zero talk or use of a Taco Chain case used in any dual kits.
__________________
1990 Xcab beast of burden 3.0 Rebuild/Precision balanced w/OS valves Custom ported/welded Intake manifolds Downey headers, Jacobs Ign 4" Trail Gear SAS + rear Kit R151 + Dual cases (2.28+4.7) 5.29's,Tru Trac/Lockright on 35 BFG's 140A GM CS144 alt/Hyd assist steering DOA Racing = $1200 lesson in who NOT to deal with Last edited by Ganoid; 12-15-2006 at 12:34 AM. |
#10 (permalink) | |||
Quote:
Quote:
OK maybe, but doubt it's significant maybe, but wonder how significant chain drive is 23 spline behind a R series transmission Same - 23 spline for R- series transmission Already in there as it comes stock I guess if you count each link in the chain a moving part Duh - so they can make more money off ya That wouldn't necessarily be true So could chain drive with the right adapter - what's the point? Quote:
200x4.7x2.57 = 2416 ft-lbs!
__________________
| Tags |
| count, crawler, info, marlin, mc10, spline, tacoma, tcase |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Transfer case ? | MNBOY | 86-95 Trucks & 4Runners | 3 | 01-13-2006 07:55 PM |
| What transfer case do I have? | TRunner | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 07-21-2005 09:31 AM |
| Transfer Case HELP !!! | 4Hummer | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 07-20-2004 06:48 AM |
| how much $$$ for a transfer case? | yotaluver | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 05-31-2004 09:14 PM |
| Transfer case | bayrunner | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 05-05-2004 08:52 PM |
