Trans Oil Temp Light Came On
Old 02-01-2013, 07:56 AM
greg mgm's Avatar
Trans Oil Temp Light Came On-OD Switch Question
Last night while driving from Palm Springs to Banning (slight uphill grade) my trans oil temp light came on. I pulled off the freeway for a short while, the light went off, then I continued home with no issues. Maybe it was my fault because I didn't turn the OD off. I know when the trans is in overdrive and you go up a grade, it downshifts (or slips) causing the engine rpm to go up 500 rpm or so. My question is, do I need to turn off the OD every time I drive up a grade? What is happening in the trans when it downshifts in OD?
Specs- 91 4Runner 3.0, 152k mi, auto, new engine, new radiator, vehicle new to me.
Old 02-01-2013, 08:27 AM
locked fj80's Avatar
it just shifts to the next lower gear to get more power from the engine overdrive is just another gear
Old 02-01-2013, 10:37 AM
orbital02's Avatar
Agreed... Does anyone know if you can "tap" into whatever temp sensor is on the transmission? I want to actually see my trans temperature
Old 02-01-2013, 11:16 AM
Co_94_PU's Avatar
No you'd have the add a temp sending unit some where, the light is controlled by an idiot light type switch eg only active when it's over point X.
You could rig one up near the cooler inlet pretty easy.
Old 02-01-2013, 11:24 AM
orbital02's Avatar
Cool, thanks for the idea!
Eggslinger
06-08-2019 03:32 PM
09-04-2015 09:27 AM
Sandman
07-14-2015 12:36 PM
Poncho0206
07-10-2015 06:21 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Trans Oil Temp Light Came On
