Trans. leaking
Old 05-07-2010, 07:37 PM
coronadrinker85's Avatar
Trans. leaking
hey guys I have a '87 with a 22r and it seems to be leaking from the top of the trans around the area of the stick shift. i sprayed it off a couple times with degreaser this evening so it will be cleaner when i get under there tomorrow. My question is, that the heck is up there that can be leaking? It has never leaked in the 24 years my step dad had it, now i have it and it leaks.... WTF
Old 05-07-2010, 07:56 PM
Kiroshu's Avatar
I'm assuming its a manual? Its prob leaking out the fill plug. Pretty common on these other wise just let us know tom.
Old 05-07-2010, 07:58 PM
yes it is a 5 speed. Is the fill plug locate on the drivers side? sorry for the dumb question, but I'm very new to these trucks.
Old 05-07-2010, 07:59 PM
scuba's Avatar
Shift plate retainer gasket, most likely.
Old 05-07-2010, 08:02 PM
PlanB's Avatar
x2 on that. My 22r manual is soaked up there too. Its not the fill plug on mine.
Old 05-07-2010, 08:07 PM
Kiroshu's Avatar
Yes its on the Drivers side.
Old 05-07-2010, 08:09 PM
hhmmm retainer gasket you say. taking a wild guess and im going to say that that's dead nuts on the top of the trans where i cant see it right?
Old 05-07-2010, 08:12 PM
Kiroshu's Avatar
yea just take the center console out and top boot(s) and you can get to it inside the truck
Old 05-07-2010, 08:14 PM
No kidding, man I'm loving this truck more and more every day. Is it a pain is the butt to change out (assuming that that's it)
Old 05-07-2010, 08:15 PM
Kiroshu's Avatar
Not really. Like i said you can sit your butt right in the drivers seat and change it.
Old 05-07-2010, 08:17 PM
cool, thanks for your help. I'm going to go check it out right now
Old 05-07-2010, 08:29 PM
well, its sure greasy up there but its hard to tell what is what because its still wet from her bath.
Old 05-07-2010, 08:37 PM
scuba's Avatar
Pull the shift boot, you'll be able to track it down if you can see from up top..
Old 05-07-2010, 08:44 PM
I did, but the drivetrain is all wet and its dark out. If it is the gasket is that something they sell at autozone or is it off to the stealership for me?
Old 05-07-2010, 09:08 PM
scuba's Avatar
Go to the dealership, it's like 5 bucks, I think you'll need two though. Just ask to look at thre diagram
I needed two for my Tacoma.
Old 05-07-2010, 09:32 PM
one for each shifter?
Old 05-07-2010, 09:44 PM
Kiroshu's Avatar
Yes one for the 4wd and the gear shifter
Old 05-07-2010, 11:19 PM
scuba's Avatar
LOL.
I meant, on the transmission shift plate retainer, mine uses 2 gaskets. One on top of a little teeny aluminum plate, and one on the bottom. The gaskets sandwich the aluminum plate and then it all gets bolted in between the trans and the shift plate.
That's why I said look at the diagram that the parts guy looks at.
Old 05-10-2010, 09:27 AM
So I called the dealer today and they are telling me its like 50 bucks because there isn't a regular gasket its something else (i forgot what he called it) is this right?
he's gone
7
12-03-2019 07:08 AM
akamon808
3.4 Swaps
12-16-2015 08:45 PM
TACOJO
11-27-2015 05:26 PM
Tigbucket
07-30-2015 07:29 PM
Avenged
07-09-2015 07:55 AM
Quick Reply: Trans. leaking
