Trans Cooler Question
I have a few leaks from the rubber hoses on my trans cooler. Is the only place to get replacements the manufacturer of the trans cooler itself, ive went to a few parts stores and they couldnt help me?
Thanks Justin van Dok
i have a Derale trans cooler, and my hoses leak too. check with any supply company that sells hydraulic equiptment. they should be able to get the hoses or just call the manufacturer
Is it the radiator fittings or do you have an aux trans cooler? You best bet is to take the hose off and take it to your auto supply of choice. They should have the tools/resources/knowledge to figure out od/id/fittings and get what you need. When I worked for a shop we generally had to send parts back with the original to determine what was ACTUALLY going to fit, as we got the wrong part very often from our local carquest, napa, etc.
this_guy
08-10-2015 10:44 AM
Poncho0206
07-10-2015 06:21 PM
