Tranny Swap: 89 into 87?
Old 06-06-2008, 07:55 PM
grayguy's Avatar
Ok, well the 5spd in my 87' 4runner took a dump. I have an 89' Truck that is in pretty sad shape, but the T-case/tranny are good. Is there any reason that I can't take the T-case/tranny out of the 89' and have it bolt right into the 87?
Old 06-06-2008, 08:07 PM
Yota82's Avatar
Should be no problem at all.
Old 06-06-2008, 08:27 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
It'll work just fine. I'd investigated the whole thing when I was pondering swapping all of the powertrain from my '86 to an '87 with a virtually rust-free frame and body. All the mechanical components fit interchangeably from the 1st to the last 1st gen. models 4rnrs.
Old 06-06-2008, 08:34 PM
grayguy's Avatar
That's great news! I was 99.9% sure it would work but figured I should check before getting the tranny all the way out of the 89'. Hopefully I can get it done tomorrow, because driving the 4rnr with a 2spd manual blows (terrible grinding/clunking/whining in 2nd, 3rd, and 5th gears)!
Old 06-06-2008, 08:39 PM
4Crawler's Avatar
Assuming both trucks are the same engine, should swap out. Only minor difference in the 4-cyl. t-cases is if one is a top shifter and the other a forward shifter. If so, no problem as long as you swap the tranny and matching t-case, aside from possible minor differences in shifter locations with the floor.
Old 06-06-2008, 09:14 PM
Staff
DeathCougar's Avatar
As Roger said, you will have to modify the floor slightly to get the shifters to fit correctly. And it may or may not work exactly right with your center console (assuming you have one)
The only down side is losing the top shift transfer case, which only really matters if going to dual cases.
Old 06-07-2008, 04:28 AM
grayguy's Avatar
Well, this truck was auto-to-5spd swapped before I bought it, so it doesn't have a console, and the shifters are kinda odd anyway. I wont be getting rid of the old case and tranny, so I'll have them around if i ever want to go doubler. I am actaully considering trying out the dual Trannies route instead when i can afford 35x12.5s
Old 06-16-2008, 03:42 PM
grayguy's Avatar
Ok, well I finally finished the swap. Oddly enough, both trucks had top shift T-cases in them, so the 87' definitely didn't have an 87 tranny in it. The only real trouble was getting the top 2 bolts out of the tranny on both trucks...that sucked.
Old 06-16-2008, 07:12 PM
bigtrucknwheels's Avatar
Location: Where it always works if you work it, in Sunny Selinsgrove, PA
glad to hear it went well for you.
ladybugRC
458
08-21-2020 10:41 AM
TheBFA
02-15-2020 06:55 AM
live4soccer7
05-11-2016 06:52 PM
Davebarbier
11-03-2015 03:28 PM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: Tranny Swap: 89 into 87?
