Tranny Question
Tranny Question
I am need of a new transmission (5spd) 88 4runner. I went to the Marlin site to get a quote and to my surprize the site showed that the W56 for 88 Toyota is a AX15. This transmission is used on Jeeps with 6 cly engines. Does anyone know if a AX15 from Jeep will fit the 22RE engine? Seems that I can get a used AX15 for pretty cheap.
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
The AX should be the R-150...
Then you'll have the trouble of the bell housing and tail shaft for the TC you need to use...
http://www.novak-adapt.com/knowledge/ax15.htm
Here's the AX5. That's the one you're thinking about...
http://www.novak-adapt.com/knowledge/ax5.htm
Tonetrk
08-06-2015 10:06 AM
Iceman4193
07-15-2015 04:48 PM
madxman21
07-09-2015 10:26 AM
