tranny problems
Old 08-18-2008, 08:23 PM
bubba osu1's Avatar
tranny problems
i have a 1990 4runner that runs great but will not go into any gear in the trans.it is a automatic
Old 08-18-2008, 08:35 PM
JDMSLIK's Avatar
check your fluid
Old 08-18-2008, 08:41 PM
cpizzle42's Avatar
count your bolts on your tranny pan, if you have 21 bolts, then it takes 4.8 quarts. Hope this helps
Chris
Old 08-19-2008, 02:25 PM
bubba osu1's Avatar
i have replaced the filter and fluid.with the truck running it acts like it is in park or neutral no matter where you put shifter.no change in rpm or anything.
Old 08-19-2008, 02:32 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
This happened in my stepmom's exploder.....it was her torque converter
Old 08-19-2008, 02:45 PM
zlathim's Avatar
Did you do the service to try to fix the problem, or did the problem start right after the service?
Dieselmann
02-19-2019 02:57 AM
shadowbirdie
07-21-2015 10:38 PM
Iceman4193
07-15-2015 04:48 PM
madxman21
07-09-2015 10:26 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: tranny problems
