tranny help - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-10-2006, 11:28 AM   #1 (permalink)
neilan's Avatar
tranny help
today after drving home from my mornign workout I dropped my buddy off at his house adn when i tried to shift into reverse it grinded. I stopped made sure i had the clutch all the way in then tried again it still grinded. Then i turned to truck off and put it in reverse and started it and was able to back up his driveway. Then driving shifts became very hard and i really had to muscle it into first then also into secong but third was ok. I got home and tried reverse again and i still would grind. I have a 87 4runner with a 22re and 5spd. I am wondering what could be happening and mabey what needs fixed?
neilan is offline
Old 07-10-2006, 11:38 AM   #2 (permalink)
ovrrdrive's Avatar
Did you check the gear lube level?
If it runs out of oil it will do crap like that. I'd start by getting a quart of gear lube and just squirting it in there so you can see if the level is ok...
__________________
'95 xcab - SOLD
'03 4runner V8 SR5 completely stock
ovrrdrive is offline
Old 07-10-2006, 11:40 AM   #3 (permalink)
neilan's Avatar
no i didnt but i will try that and that would be awesome because tranny repairs arn't cheap
neilan is offline
Old 07-10-2006, 12:06 PM   #4 (permalink)
neilan's Avatar
well i check the level and when i pulled out the plug fluid started coming otu so that means the levels is good so now i still have no clue what it could be.
neilan is offline
Old 07-10-2006, 12:40 PM   #5 (permalink)
sounds like the clutch isnt fully engaging. try bleeding the clutch. You can also double clutch for the time being and see if that helps.
MMA_Alex is offline
Old 07-10-2006, 01:16 PM   #6 (permalink)
Flash319's Avatar
Your clutch is not disengaging. Your pilot bearing could be sezed solid. Your master or slave cylinder could be no good or leaking.
Flash319 is offline
Old 07-10-2006, 05:18 PM   #7 (permalink)
neilan's Avatar
i figured out what was wrong with it its all brand new stuff the master the slave and the clutch (clutch 600 miles ago) but anyway i found otu that i need to adjust the pedal because the pedal would hit the floor befor the slave would push far enoguh to completely disengage the clutch so hopefully when i adjust it tonight it should fix the problem.
neilan is offline
Old 07-10-2006, 05:50 PM   #8 (permalink)
90runnner's Avatar
Send a message via AIM to 90runnner
i know a common problem with early gen 2 4runners is the bracket that holds the pedals will actually crack, allowing it to flex instead of the pedal pushing through all the way. i had it happen to my old 4runner(1990). i pulled it out and layed a good thick bead over the crack and in some other places that looked weak and it worked great. if you search on here i know there is a thread about this, thats how i found this solution
__________________
<===i miss that one
Mine:
1991 Landcruiser
2in OME lift
33in BFG A/T's
The girl's:
2001 4runner
3in Revtek, 3in body lift
35in MT Baja Claws
Marlin sliders
TJM front bumper
90runnner is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
is my tranny going? derK 95.5-2004 Tacomas & 96-2002 4Runners 13 01-15-2007 07:22 PM
I Need A Tranny Fish Taco The Classifieds GraveYard 7 01-08-2007 09:44 PM
Replace Turbo Tranny w/ Non-turbo tranny Bill 86-95 Trucks & 4Runners 0 08-20-2006 04:54 PM
Does overfillin the tranny w/ fluid hurt the tranny? CILO 86-95 Trucks & 4Runners 4 02-02-2006 10:44 AM
87 yota tranny options. I need tranny, what all will work. Stock is g52 yotanothing 95.5-2004 Tacomas & 96-2002 4Runners 2 06-30-2005 10:06 PM
2009 InternetBrands, Inc.
