Tranny Help
Old 05-05-2008, 04:04 AM
Team420's Avatar
Tranny Help
I have an auto tranny, a340h i believe? I cant get her to shift into o.d. 50mph and im taching 3k... I have narrowed this down to a solonoid or coolant temp sensor, Which solonoid would I need to check? How to check it? can these be cleaned? I got my truck swamped last week, and finaly have everything else working, and I;m thinking I may have some sand or dirt causing a solonoid to stick... I should mention that it shifts fine 1-2 2-3...just no o.d.
Thanks...Jim
Old 05-05-2008, 04:22 AM
Team420's Avatar
also...is it possible to do a 5spd swap, if so how difficult and costly would this be? I might have a 5spd, from a 92 runner for free!!
Old 05-05-2008, 01:25 PM
Team420's Avatar
haha...found a constant drip on one of the cooler lines...guess that would do it, going out in a bit to see if it just needs to be tightened, dunno why it is all of a sudden leaking, but it is a constant drip..drip..drip, surprised i still have fluid
Old 05-05-2008, 01:48 PM
mt_goat's Avatar
Thanks...Jim
Any trouble codes?
http://personal.utulsa.edu/~nathan-b...31diagnosi.pdf
Actually after filling it up with dirty water, I'm suprised it shifts at all. But yeah a stuck solenoid would be my guess.
It looks like from this: for the OD to work while in drive, both #1 & #2solenoids need to be "off". So maybe one of them is stuck "on".
http://personal.utulsa.edu/~nathan-b...28operatio.pdf
If it were me and I had the pan off anyway I'd just replace them all. Things as small as lint from a rag can cause problems with solenoids. Have you flushed it good yet?
This may help too:
http://personal.utulsa.edu/~nathan-b...38onvehicl.pdf
Heck, here's the whole 93 truck FSM:
http://personal.utulsa.edu/~nathan-b...fsm/index.html
Old 05-05-2008, 02:20 PM
Flash319's Avatar
Is your light on in the dash? The switch in the handle is garbage and will short causing no OD shift. You could have a blown light in the dash and your switch is bad. Yank all the guts out of the switch and see what you get.
Old 05-05-2008, 03:15 PM
Team420's Avatar
Originally Posted by mt_goat
Any trouble codes?
This may help too:
Yeah, have the links for the fsm.. no trouble codes. my problem is different than whats explained in the fsm, When the o.d. light is on.. it "locks up" to 3rd, When I have the o.d. on (light off) it wont lock up to third almost like its trying to shift up...Leads me to believe it's not a solonoid problem, and not likely electrical...I did flush it out,,,used 30 quarts and a pint of seafoam trans tune...fluid is clean and all other shifts are as they were, I got under the truck and watched, and noticed one of the cooler tubes is leaking, seems it has rusted through on top, and i'm getting a constant drip, weird thing is...level reads the same on dipstick, and it wasn't doing this when i flushed. gonna get the new pipes and hope that fixes the problem. Also noticed my oil filer is leaking... water really sucks...LOL Going to snorkel it for next time.
ladybugRC
458
08-21-2020 10:41 AM
TheBFA
02-15-2020 06:55 AM
live4soccer7
05-11-2016 06:52 PM
Davebarbier
11-03-2015 03:28 PM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: Tranny Help
