tranfercase question
I have a 86 pickup with 4cly and where my rear seal or bearing on my tranfercase to rear drive line has movement. My question is their a seal or bearing? Also it not my u joints.
It may just be a loose flange, it is very common. Look at the output shaft and nut while wiggling the flange. If the nut is loose get a seal and a nut, take off the flange, clean the flange, splines and washer. Silicone the splines and reassemble. Sorry I forget the torque and my FSM is out in the garage.
TJWilly
07-31-2015 02:05 PM
