TPS adjustment now can't accelerate...
Old 12-07-2010, 07:44 AM
quiggs12's Avatar
So, I was having some issues with adjusting my timing. I was not able to set the base timing and when I unshorted the proper diagnostic terminals the ignition did not advance as it is supposed to. So, I posted the issue on here and was given some good advice regarding the TPS being the cause. Sure enough the FSM backed that up and I made an attempt at adjusting it.
After adjusting it I was able to set the base ignition timing and have it properly advance once the shorted terminals were removed. HOWEVER, now my truck (22R-E, 87) can't accelerate! When I hold the throttle open it does not increase the RPMs much if any. Instead it has a delay and sounds like it is taking a break from running... What did I do or what does this sound like? Could it be the TPS needs to be changed or is it something else? Thanks
Old 12-07-2010, 07:49 AM
Marc's Avatar
Unplug the TPS and see if that helps.
If it does then it's either the adjustment or the TPS itself.
If that doesn't help it could mean you've adjusted your timing wrong.
Old 12-07-2010, 08:06 AM
AxleIke's Avatar
The TPS must be adjusted within a few thousanths of an inch. I recently replaced the TPS on a 3.0 and 2 thou made a huge difference. The TPS is the same for both.
You probably already did that, but I was suprised at how sensitive it is.
Old 12-07-2010, 08:11 AM
OrRunner's Avatar
http://www.4crawler.com/4x4/CheapTri...PositionSensor
Old 12-07-2010, 08:48 AM
quiggs12's Avatar
When I unplug it it accelerates fine! Therefore, I am assuming that it is shot...
Old 12-07-2010, 08:55 AM
Marc's Avatar
Or adjusted incorrectly. You can test it.
Old 12-07-2010, 09:17 AM
quiggs12's Avatar
I did test it and couldn't get it anywhere near the specs...
Old 12-07-2010, 01:51 PM
Marc's Avatar
Then I guess it's shot.
zytra
01-24-2019 03:16 PM
ZGjethro
06-07-2017 11:04 PM
the_supernerd
10-01-2015 09:20 PM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
dbollier123
09-29-2015 05:23 PM
Quick Reply: TPS adjustment now can't accelerate...
