toyota pickup & trailer signals
Old 02-21-2008, 06:31 PM
jdw1's Avatar
when i have my trailer hooked up to my truck and turn the blinkers on, my voltage gauge goes up and down erratically. the blinkers on my truck will work fine, but the trailer blinkers wont even blink. the trailer in wired correctly, and i have a new taillight converter on it. any ideas what the problem is?
Old 02-21-2008, 06:39 PM
MMA_Alex's Avatar
I'd bet you've got a bad ground. whered you wire the trailer ground into?
87toy.'s Avatar
need a better ground most likely or wherever your ground is it might need to be grinded down a little bit so it has better contact.
, or your fuses and or relays need to be replaced. What year is your truck? sometimes old wires will not pass all the current
or... your alternator needs replaceing
Old 02-21-2008, 06:49 PM
jdw1's Avatar
I have it grounded to the truck and the boat trailer. my truck is an 87. what relay would i need to replace? how can i tell if my altanator is bad?
Old 02-21-2008, 07:09 PM
Jay351's Avatar
Just to clear things up its normal for your volt guage to fluctuate when you have your blinkers on.
Old 02-21-2008, 07:19 PM
jason191918's Avatar
Do you have a converter is that generation different than my 92?
Old 02-21-2008, 08:24 PM
MMA_Alex's Avatar
where on the truck? if its grounded to the hitch, or onto a rusty/coroded spot its not a good ground
6th Gear
19
12-10-2019 07:31 AM
Weidle
01-21-2019 05:39 AM
Aleeex_u
06-05-2016 06:52 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: toyota pickup & trailer signals
