Toyota pickup 22re help
Old 03-14-2012, 07:45 PM
Dreidel's Avatar
So ive been having this problem with my 22re starting easy when it's cold but when it's hot it seems like it has a dead battery (like cranks 1 revolution and then stops when it is hot but if you wait until it cools of a little bit then it starts right up) so naturally I replaced battery thing is, problem still persists Any ideas
Old 03-14-2012, 07:49 PM
Inferno451's Avatar
I'm saying it's the starter. Pull it out and get the brushes to rebuild it. Here's a good writeup on it: http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Old 03-14-2012, 08:01 PM
Dreidel's Avatar
Thank you I'll check it out rebuilt the engine myself and put 1300 trouble free miles on it (except for accidentally crossing the vaccuum lines going to the egr modulator not bad for only being 16
Old 03-15-2012, 10:58 AM
Night-rider123's Avatar
Ignition timing could be to high.
Old 03-15-2012, 04:18 PM
Brazos's Avatar
I had a similiar issue with a '78 CJ-5 I used to own. I had header exhaust that ran close to the starter and over time would cook the starter and do exactly as you describe. Once I figured it out I got a smaller aftermarket starter with heat shields and never had another problem. Not sure what your exhaust system is like but figured I would throw the idea out there.
**Edit. It just occured to me the exhuast & starter are on opposite sides on a 22re so scratch my idea.
Old 03-23-2012, 04:03 PM
Dreidel's Avatar
lol i see what your saying though
6th Gear
19
12-10-2019 07:31 AM
Weidle
01-21-2019 05:39 AM
Aleeex_u
06-05-2016 06:52 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
zytra
06-24-2015 08:14 AM
Quick Reply: Toyota pickup 22re help
