Toyota fuel injection
Old 02-07-2009, 01:08 PM
Flash319's Avatar
I have had this link for a while and just came across it again. May be posted somewhere but a good read for newbies.
http://memweb.newsguy.com/~gtfour/fuelinj.htm
Old 02-07-2009, 01:21 PM
bigt's Avatar
good read!
Old 02-07-2009, 01:47 PM
abecedarian's Avatar
Kind of cool... approaching about 85% correct, Some factual and maybe semantic errors.
Shut up and leave me alone: I'm drunk and saw errors so I don't know why sober people / persons (particularly the one who wrote it) missed them.
Old 02-07-2009, 02:11 PM
iamsuperbleeder's Avatar
some good info in thurr, for those who are not aware of the info in it already
Old 02-07-2009, 02:47 PM
It lost my respect when it said there were 3 signals from the distributor.
Correct me if I'm wrong but TCCS started in 89 and the distributor from the 22re gave 1 signal (it only had one pick-up coil and one rotor with 4 lobes... can't bet more than 4 signals per 2 crank revolutions...)...
3vze had 6 lobes on one coil and 30 lobes on the other rotor.
Someone PLEASE inform and request the author to at LEAST dilineate the engines referenced... Please!!!
sory, what?
Old 02-07-2009, 07:34 PM
Matt16's Avatar
Abe when you go passed TDC can you grab be another meer.
"Use Occam's Razor to your benefit."
"Most often, the simplest solution is the best."
"Don't make it any more complicated than it has to be."
all by: me
..isn't listing the concept of parsimony 3 times un-parsimonious?
Old 02-08-2009, 04:17 PM
all by: me
Do I get 200 for passing GO?
but you should get what I mean- 4 lobes... and maybe I misspoke- for each crank revolution you'll get 2 pulses from the distrubtor on a 22re.
Critical thinking is not only a requirement of the one making a fool of himself but applies just as well to those desiring to make a fool of the one in question.
...hmm... maybe another self-inflicted quote.
Old 02-08-2009, 04:22 PM
Either...
1) prove I'm wrong, and by extension the article is correct.
2) prove I'm correct, and by extension the article is wrong.
3) prove there's enough doubt to cause the article to be questioned but take no side.
Old 02-08-2009, 05:32 PM
InternetRoadkill's Avatar
Don't know about the later gen 4Rs, but the FI on the first gens used gang-bang injectors rather than sequential FI.
Old 02-08-2009, 05:44 PM
batch fire was the norm until OBDII was mandated.
Old 02-08-2009, 09:44 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Whatdda know.....the belted earl speaks.........
Old 02-09-2009, 08:20 AM
Flash319's Avatar
This is not for a 22re it is for a different engine but is close to a standard Toyota fuel injection. This is for a 16V engine that was in the newer celica but is close enough for troubleshooting or basic understanding.
bigjstang
08-25-2021 12:41 AM
God's Bounty Hunter
07-08-2015 12:54 PM
wilbertd
07-06-2015 07:39 AM
karbin
07-05-2015 11:37 PM
Quick Reply: Toyota fuel injection
