tow capacity of a 92 3.0
hey. im new 2 the forum,
i was wondering if i can tow a 3100lb corvette from maine to florida without it blowing up
if its an auto i think you could do 60-70 just fine..i've towed a 15ft alumnium boat that speed and it wasn't very hard at all...of course it doesn't weigh 3100 lbs either...
I towed an 18 foot trailor with a 4-wheeler a few deer stands and about 200 lbs of corn. I didn't have to much trouble but you could really feel it on the hills. You can do it but just don't expect to do it very fast. This is really one of the few down sides to these 4-runner's they have just enough power to get you by.
Cancel overdrive and only use it when you have reached cruising speed and are on fairly level road. Don't use overdrive on hills. The first thing to go in most autos is the high clutch. You should also have an aftermarket transmission cooler and completely by-pass the radiator cooler.
with the weight of a trailer, you would be at 6000, unless iyour are using a tow dolly. Tow dolly, and corvette....
Look into the ebay vehicle moving companies. I looked into moving a trailer, it wasn't that expensive to have moved, but that is a lot different from a corvette
Yes, it can be done, then again, most 3.slows are lucky to tow themselves.
I'd be a tough haul that's for sure. If the Toy's got any weak spots you'll be sure to find them.
Better off towing the Toy w/ the Vette.
mirabile4runner
09-03-2015 07:15 AM
