Torsion Bar Question
Old 07-19-2011, 03:27 PM
clk_cpa's Avatar
I'm in the process of making the front end of my truck stronger. So i'm going to do the idler arm/bronze spacer mod, install idler truss from northwest, install a hecketorn steering stabilizer etc... The question is should torsion bars be replaced for the ONLY reason of running larger tires?. I have a bracket lift so the stock torsion bars I have right now are not cranked up, or at least I dont think they are. There seems to be 2 schools of though on this. Northwest says specifically that to run larger than stock tires, it's a good idea to use larger torsion bars.
http://www.northwestoffroad.com/parts/torsionbars.php
But then you have 4x4wire.com saying that torsion bars are for sprung weight, in which case they would not have any impact when it came to wheels/tires, which are unsprung weight.
http://www.4x4wire.com/toyota/tech/torsion_bars/
These are 2 of the many articles/opinions I found online. So, should I replace the torsion bars JUST for running bigger tires?
Old 07-19-2011, 04:27 PM
MudHippy's Avatar
Answer = NO, because wheels/tires are not sprung weight.
Old 07-19-2011, 04:39 PM
clk_cpa's Avatar
thanks, it's interesting that a place like northwest would say it needs to be changed for bigger tires considering they have been doing working on yotas a long time
Old 07-19-2011, 06:03 PM
flashkl's Avatar
if you run large tires, you are more likely to have heavy armor, winch etc which would equate to more sprung weight...that may be their justification
Old 07-19-2011, 07:43 PM
angrybob's Avatar
I went to 24mm rancho t-bars after adding a bunch of weight to the front end..bumper, winch, etc. Cranking up your stock t-bars to accommodate a weight increase is fine. Cranking up t-bars for 'lift' alone (w/o any add'l weight) isn't the greatest move. You might get a bit of left but you will also get a harsh ride 100% of the time.
My t-bars were cranked from the PO and the bigger bars with the extra winch, etc. weight set at the spec height have a much better ride than before.
Old 07-19-2011, 10:10 PM
clk_cpa's Avatar
Ok thanks for the replies. I'm not going to bother with the tie rods. I dont have a heavy bumper or winch. I checked out the autozone idler arm and it's only $36. Is this the right one? Model FA5040? Based on my research it is, but the price is half of what it should be. Also, how good is the stock pitarm and are there any stronger aftermarket ones?
Old 07-20-2011, 03:39 AM
waskillywabbit's Avatar
Search Northwest. They have a reputation.
:wabbit2:
Old 07-20-2011, 05:05 AM
xxxtreme22r's Avatar
FA5040 regardless of what autozone tells you IS the right one. And yes it's only like $36. That's the only one as far as I know that accepts the SDORI bushings. Unless your jumping your truck, have a SBC 350, 1uz or any other v8 conversion, winch/bumper you don't need thicker torsion bars.
Old 07-20-2011, 07:12 AM
clk_cpa's Avatar
:wabbit2:
what do you think about their idler truss? any experiences with it?
Old 07-20-2011, 07:58 AM
MudHippy's Avatar
It's very similar to the old Downey idler arm brace design, in construction and appearance. I've haven't heard too many of complaints about either. And since Downey went under, that's the only one around. So what other choice do you have besides making one yourself?
FYI, Downey used to perpetuate myths about their 26mm torsion bars too. If somebody is trying to sell you their product they are more likely to tell you things that aren't exactly true about it. Snake oil salesmen's tactics, in other words.
Old 07-20-2011, 09:07 AM
MaK92-4RnR's Avatar
you should look into SAW ( Sway-a-way ) Torsion bars. Relatively cheap, powdercoated red, and great customer service. If you have a lot of weight on the front ( like I do ) i'd definitely pick some up.
Old 07-20-2011, 12:43 PM
clk_cpa's Avatar
So do you think the idler truss that northwest sells is worth buying?
Old 07-20-2011, 12:48 PM
MaK92-4RnR's Avatar
an idler truss does help with the "strength" of the idler arm. If you're really worried about damaging it, get a nice steering stabilizer, and a truss...
Old 07-20-2011, 01:27 PM
MudHippy's Avatar
Personally, no. I made my own using 1/4" plate. Their's is only 3/16".
I would buy it if I couldn't make my own. It's better than nothing.
Old 07-22-2011, 08:18 AM
clk_cpa's Avatar
ok thanks. I got the idler arm from autozone, but cant find any stamps anywhere. Neither FA5040 or the 555 that I should avoid are stamped. i hope I got the right one
Old 07-26-2011, 02:25 AM
Utah4Runner86's Avatar
What year is your rig? I don't remember the model number, but I do remember that the first arm Autozone gave me was wrong... their computer thinks '86 runners have a solid front axle.
Old 07-26-2011, 07:34 AM
clk_cpa's Avatar
it an 88. the box said fa5040 so did the guy behind the counter but what does he know. I installed the bronze bushings so we'll see how long it will last
4.34runner88
08-11-2018 10:44 AM
andrewtexas123
07-06-2016 01:49 AM
Jcrawl94
10
10-24-2015 04:34 PM
coffey50
07-28-2015 10:55 AM
DrZero
18
07-24-2015 11:31 PM
Quick Reply: Torsion Bar Question
