torque converter problems? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-04-2006, 02:54 PM   #1 (permalink)
so i just got off the phone and the shop talked to some people and think the tranny converter is shot, but you need to pulll it to measure it and see what one you have, but anyways the tranny shop said that in the early 90's they used a 2 part shifting mechinism with a checkvalve and they tend to get "clogged" which is why in low range itll run like a bat outta hell and when you put it in high it wont "have any go power" they said even know the truck just had all this tune up work done to it, it kept fowling out plugs and sensors cause of the restriction, which is why it wouldnt want to start easy, so before i pay another shop to do more work and pull my tranny, do you guys think this may be it????????????????
gsxr750 is offline
Old 12-04-2006, 03:06 PM   #2 (permalink)
Robinhood150's Avatar
Send a message via AIM to Robinhood150
Proper grammar goes a long way in describing problems to people. Can you repeat that in english?
__________________
Steve. '93 4Runner V6 Auto 4x4
Robinhood's Lair. || Gettin' Off 4wd Club member
Lots for sale:5.29 ARB IFS third member... Click
Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in:
a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat...
Lesson...Stay on the TRAIL!
Robinhood150 is offline
Old 12-04-2006, 08:36 PM   #3 (permalink)
trythis's Avatar
x2 what???
punctuation
__________________
89 DLX xtra cab 4x4 22re Auto with 210,000, 225 75R 15, Stock except, "new" 2000 toyota cd/radio, rear speakers hidden in the back seat, SR5 instrument cluster, factory clock. dead aftermarket cruise and some matching blue door pockets! New timing chain with Engine builders front end rebuild kit. Tokico RT trekmaster shocks <-like them.
I found the turtle in my yard, after mowing over it and it was fine! Old toyota trucks are like turtles: slow, steady and durable.
trythis is offline
Old 12-06-2006, 05:38 PM   #4 (permalink)
my trucks sluggish as hell and just been getting worse and worse over the summer, now it wont go up hills, if i put it in low range itll have power, if i put it inhigh range it wont even spin the tires in dirt. the basic tune up things have been all done and it keeps fouling out the plugs cause of the restriction due to the torque converter being shot when u test drive it, it will have a restriction on the motor so it fouls out the plugs , anyone hear of a torque converter going bad?
gsxr750 is offline
Old 12-06-2006, 06:03 PM   #5 (permalink)
Quote:
Yup, you can blow a TC and that will call for a tranny rebuild.
Pull the pan (tranny) and take a look. See what, if any debris is in the pan, what color, how much, etc.
Are you sure that the tranny is shifting correctly and then it's starting in 1st gear, etc. ?
Fred
FredTJ is offline
Old 12-06-2006, 06:25 PM   #6 (permalink)
Bumpin' Yota's Avatar
Send a message via AIM to Bumpin' Yota
low range?? high range?? What?
How does a torque converter have ANYTHING to do with fouling plugs???
You've got more than one issue and they are unrelated....
The fouling plugs could be a LOT of issues, but rich condition, detonation, oil in the intake are the first things that come to mind. I've never heard of a TC blowing up on such a low power application as a 3vze or 22re or 5vzfe for that matter.... Id solve the fouling plugs issue first personally.
__________________
3vze, 4x4, sr5, 90, auto, LSD
2x dB Drag World Finalist
2003 Nopi Nat. Street B champ
2004 SBN Street C champ
2004 SBN Advncd NW Champ
2004 Former WR Holder in NW.
SPL: 159.8db @ 42hz
In loving memory of Jamie Riggs 5/15/85 - 10/8/04
Bumpin' Yota is offline
Old 12-06-2006, 08:12 PM   #7 (permalink)
Don't sound like no torque converter problem that I've ever seem. If the TC is bad in high range then it still gonna be bad in low range. I believe that you've got a secondary ignition problem that's causing the lack of power.
__________________
94 Toyota P/U Ex-Cab 3.0 Automatic 4X4
dstrick32 is offline
Old 12-06-2006, 08:39 PM   #8 (permalink)
toyota_mdt_tech's Avatar
No, not at all. It sounds like you might have an open in a solenoid circuit and its trying to start off in too high of a gear. You have 2 solenoids which give you your four shifts. A combo of the 2 solenoids being on/off is what does it. It require both on to get 1st gear, all off to get 4th or OD. If you are missing one, you will get a 1 and a 4th gear, while the opposite solenoid working wil start you out in 2nd and shift to 3rd only. I'd check codes. I suspect someone either doesnt understand the tranny or does and s trying to "kink ya"
__________________
Toyota Master Diagnostic Technician
"MDT"
1998 Toyota Tacoma TRD V6 4WD 5 SPD
1998 Chevrolet K1500
1999 Toyota Camry
2003 Toyota Highlander 4WD
2007 KTM 85SX 17/14
2006 KTM 300XC-W
2005 KTM 65SX
2004 Kawasaki KLX 110
2003 Honda XR50
2002 Yamaha TTR 125L
2002 Kawasaki KLR650
2002 Suzuki Eiger 400 4WD
2004 Cargomate<--link
GeePaw® Racing<--link
toyota_mdt_tech is offline
Old 12-07-2006, 12:12 PM   #9 (permalink)
cweich's Avatar
Auto Trans Help
Quote:
What tells the solenoids to turn on and off, i have a 85 auto 22re that will only shift manually....it starts in high if you put it in drive and that is all it does, all the gear are there if you shift manually.
cweich is offline
Old 12-07-2006, 12:49 PM   #10 (permalink)
Quote:
Tranny ECU, its seperate in the 85's. There is input to the ECU (speed etc) and output controls solenoids.
__________________
"MDT"
1999 Toyota Camry
2007 KTM 85SX 17/14
2006 KTM 300XC-W
2005 KTM 65SX
2003 Honda XR50
Old 12-07-2006, 01:55 PM   #11 (permalink)
cweich's Avatar
Any way yoy could tell me what color of wire i am looking for...i have found the controler under the shifter...but not sure where to gofrom there.
Thanks for the fast reply
cweich is offline
Old 12-07-2006, 05:07 PM   #12 (permalink)
cweich's Avatar
i do nnot have a speedo cable right now...will that affect it. if so can i just hook the end up to the trans and get things working??? or where is that speed sensor located that is tied to the speedo cable?
cweich is offline
Old 12-08-2006, 08:56 AM   #13 (permalink)
cweich's Avatar
is there a way by pass the speed sensor in the dash??
cweich is offline
Tags
2003, 2006, 4th, 4x4, bad, converter, gear, honda, kawasaki, klx110, problems, sierra, tacoma, torque, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Torque Converter tampabayota General Vehicle Related Topics (Non Year Related) 8 03-12-2007 03:12 PM
torque converter woes.... 95RunnerSR5 86-95 Trucks & 4Runners 6 09-04-2006 04:43 PM
Could this be the torque converter? Del General Vehicle Related Topics (Non Year Related) 1 01-01-2006 03:17 PM
torque converter lockup problems toyotaoffroad91 95.5-2004 Tacomas & 96-2002 4Runners 0 08-12-2005 09:37 PM
Torque Converter Lockup 93ToyKid 95.5-2004 Tacomas & 96-2002 4Runners 9 03-17-2005 05:50 AM
2009 InternetBrands, Inc.
