Toolbox CB Mount..
Old 10-29-2008, 10:03 AM
Trustyrusty's Avatar
Toolbox CB Mount..
Anyone know where I can get a mount for my CB Antenna (4' Firestik) to mount to a toolbox? I took my rollbar out cause it got in the way and I need a toolbox more than that.. So I'm putting my toolbox back in but neet a mount for my CB antenna cause my antenna is rail mounted..
Old 10-29-2008, 10:06 AM
andtheman1988's Avatar
Radio Shack has them, or check at your local truck stop they should have everything you need.
Old 10-29-2008, 10:07 AM
ryantowry_81's Avatar
i have always used the clamp on mounts they use on semi trucks and loose the backing plate and just drill four holes in the box, always worked well.
Old 10-29-2008, 10:23 AM
Aight.
Old 10-29-2008, 10:32 AM
georgiayota's Avatar
I have mine mounted on a piece of 2in square tubing that i bolted to the toolbox. I bought one of those rail mount L brackets and bolted to the square tubing. I use the square tubing because you want the antenna to be atleast an inch and a half from any metal.
Old 10-29-2008, 12:54 PM
abecedarian's Avatar
the clamp on with the four bolts drilled on a vertical surface is probably the most stout solution you'll find. the mounting stud, where you just drill an appropriately sized hole and through-bolt it on are good only with thicker metals since the antenna will whip around while you drive.
Old 10-29-2008, 01:56 PM
Jay351's Avatar
Just a note, I read in the FSM that you should keep componants for a CB radio as far away from the ECM as possible..
Old 10-29-2008, 03:20 PM
Thanks Jay, but thanks for (RUBBING IT IN MY FACE!) that I don't have EFI.. I wish I had EFI, but then again I've never had any carb problems..
Old 10-29-2008, 03:23 PM
bet you have an ecu though.
Old 11-01-2008, 11:09 AM
Find it for me then! Haha I'd rather not look.
Old 11-01-2008, 01:40 PM
Jay351's Avatar
Well then, giver!
Nickdigg
07-07-2015 06:04 AM
crappled
12-03-2005 09:14 PM
Tacoma Dude
10-04-2003 01:14 AM
Quick Reply: Toolbox CB Mount..
