Tool for holding timing gear when removing head
Old 10-11-2013, 06:49 PM
killer305's Avatar
Is there a tool and is one necessary?
The last time I did a head gasket on a 22re I remember the timing gear dropped down slightly when I took the head off.
I was able to use a pry bar to lift it back into place when I installed the head but I imagine there is a tool to hold it so you cannot accidently skip a tooth?
Does anyone know where I can get one?
Old 10-12-2013, 04:53 AM
Rerunn's Avatar
There isn't a tool. The tool i used is call plastic zip ties! Just zip tie the chain to the cam gear before removal. When going back on if you rock the crank back and forth and pull up on the gear at the same time it'll go on.
Old 10-12-2013, 10:48 AM
killer305's Avatar
Cool thanks for the reply
Old 10-12-2013, 11:43 AM
SCToy's Avatar
I used zip ties and a piece of string holding it up to the hood.
voiddweller
19
05-02-2016 09:10 PM
DacodaYota
09-02-2015 02:13 PM
85run
07-08-2015 11:20 PM
hexrain
06-27-2015 06:17 AM
Quick Reply: Tool for holding timing gear when removing head
