Tool Box Lights
Tool Box Lights
I have a set of offroad lights on my tool box and they arent working, usally in order to get them to work i would have to push my tool box back and forth , and get them to ground better and then they would fire up. now they wont turn on at all , i checked every connector , the fuse, o btw the switch for the lights works fine . is there a possible way they are blown or something because of my tool box not haveing a good ground
Lights
Get a ohm meter (you will need it again) and ohm the bulbs , that will tell you if they are bad and you should also pay close attention to the wiring requirements for the bulbs , should they be wired in series (most common) and if so are they in series ?
The way they are wired can change the amount of current they draw and effectively kill them .
BeMiceElf
10-10-2015 09:40 PM
rushw
07-18-2015 01:46 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
skoti89
07-08-2015 12:05 AM
