Too much play in steering wheel - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 02-22-2007, 04:22 PM   #1
Lifelongtoy's Avatar
Question Too much play in steering wheel
I have a little too much play in my steering wheel. What causes that? More importantly how can I fix it?
Lifelongtoy is offline   Reply With Quote
Old 02-22-2007, 04:55 PM   #2
GSGALLANT's Avatar
Vehicle specifics always help when you're asking a question, but assuming you don't have rack and pinion steering (which I think only came out in 3rd gen 4R's), there's an adjustment on the top of the steering gear box. Loosen the lock nut, turn the adjustment screw clockwise, then re-tighten the lock nut. Do it in steps of 1/4 turn at a time, trying it out in between steps... you don't want to tighten it too much, because your steering wheel will not "self-center" coming out of a turn.
GSGALLANT is offline   Reply With Quote
Old 02-22-2007, 04:56 PM   #3
Worn tie rod ends would be my guess? Get it aligned its like 40 bucks :-D
Bejiita is offline   Reply With Quote
Old 02-22-2007, 05:00 PM   #4
91_4x4runner's Avatar
Quote:
What exactly does turning the screw do out of curiousity?
91_4x4runner is offline   Reply With Quote
Old 02-22-2007, 05:23 PM   #5
GSGALLANT's Avatar
Quote:
It reduces the backlash in the steering gear box.
Old 02-22-2007, 05:24 PM   #6
GSGALLANT's Avatar
Quote:
Yeah... check the pitman and idler arms for play also.
Old 02-22-2007, 06:18 PM   #7
Thanks everyone. Getting alignment tomorrow.
Old 02-22-2007, 10:01 PM   #8
And yah what he said about tightening that bolt/screw combo I tried that before on my old truck hoping itd make the steering firmer but after it didnt I learned what it really does.
Old 02-23-2007, 12:12 AM   #9
the_supernerd's Avatar
I also say check your idler arm. It is common for the bushings to wear in those and cause excessive play. You can rebuild them cheap if you do it yourself.
the_supernerd is offline   Reply With Quote
Old 02-23-2007, 11:07 AM   #10
Yep, like they said check your tie rods pitman and idler arms. Alignment will only do so much if those are shot. Gotta replace mine actually lol...
SwampThing is offline   Reply With Quote
Old 02-23-2007, 12:42 PM   #11
ToyYoda's Avatar
Check the power steering gear box pitman arm ball joint (which is permanently attached to the arm). Mine was bad and everything else was fine. I had 6 inches of play in my steering wheel. I drove like I was drunk everywhere I went trying to compensate for all the play fast enough to not drift into another lane or overcorrect and serve. I just bought a new pitman arm and everything is back to normal.
ToyYoda is offline   Reply With Quote
sticky power steering Up&Down 95.5-2004 Tacomas & 96-2002 4Runners 4 08-11-2015 11:04 AM
FS[SouthEast]: 99+ center console, rear air deflector, lift spacers, steering wheel terminator Misc Stuff (Vehicle Related) 3 07-27-2015 08:13 PM
Inner hub bearing glowz825 95.5-2004 Tacomas & 96-2002 4Runners 4 07-17-2015 01:28 PM
91 Toyota pickup ignition switch, key will not turn!!?? Hamonacracker 86-95 Trucks & 4Runners 7 07-17-2015 09:33 AM
This time, science has gone too far! RobotMoose Off Topic Talk 1 07-07-2015 08:36 AM
Tags
2007, 4runner, 94, drifting, fix, gear, inches, lexus, lifted, play, sc400, shaft, stearing, steering, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
