tire and rim size
Old 02-05-2008, 02:17 PM
rgrounded's Avatar
tire and rim size
Hello Toyoters...got a ? for ya. I have a 1989 4x4 pickup SR5 and was wondering how large of tire I can put on with out any modifications. Thanks Rob...also I'm still looking for a ECU 10-18-24 pin configuration for a 89 V6 3VZE
Old 02-05-2008, 02:25 PM
waskillywabbit's Avatar
31s
Old 02-05-2008, 02:26 PM
stormin94's Avatar
I'm pretty sure if you crank the torsion bars up about an inch, then you can fit 35's, or maybe 38's without any rubbing. But with larger tires, you have to increase your drive shaft diameter to cope with the added weight of the larger tires, and the increased effort to turn them. After that, you may notice that your ride is a little sluggish, so you may want to do a simple mod that yields almost 15 horsepower. this involves drilling a small hole on top of your throttle body. It fools the sensors to thinking that your cruise control is malfunctioning, and you may need to add some fluid to that. If, however you do not want to do those simple mods, then you may want to search.
Old 02-05-2008, 03:36 PM
Jay351's Avatar
33x10.50 some minor "fine tuning" in the inner fender will clear them.
Possibly even a 34x10.50 but anything wider and you need some lift or make some room with the sawzall
Old 02-05-2008, 03:42 PM
Old 02-05-2008, 03:45 PM
Fossilized
Staff
dropzone's Avatar
Originally Posted by waskillywabbit
1 out of 3 responses read the no modifications part of the post...Good catch Brian
Old 02-05-2008, 04:17 PM
nmtoy's Avatar
I have 32" BFG AT on SR5 rims, no mods, no rub. With the stock backspacing they clear fine, anything wider than stock will probably rub the pinch weld.
Robb
Old 02-05-2008, 05:48 PM
Jay351's Avatar
well technicly there are people who have run the tire sizes I posted without any modding at all. Not even bashing the inner fender with a hammer.
Old 02-05-2008, 09:26 PM
notanymore's Avatar
yeah right. just stop posting. just because hes a newbie and hasnt learned how to search yet doesnt mean you have to start feeding him crap like that.
you can go to 31s and not have a large power loss, you can fit 33x10.50 but it will be slugish unless you regear, but it can be done.
Old 02-05-2008, 09:29 PM
stormin94's Avatar
Yeah, he should know how to search. It is included in the rules that you have to read before becoming a member. We all had to read them.
Old 02-05-2008, 10:03 PM
4x4YOTA's Avatar
you can clear 31s no prob
chukarhunt
12-08-2019 11:39 AM
Griff
93-98 T100s (Build-Up Section)
09-23-2015 10:11 PM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
Gravel Maker
RuffStuff
07-27-2015 06:53 PM
Yotoder865
07-09-2015 07:51 PM
Quick Reply: tire and rim size
