tire and power question
Old 02-20-2008, 08:08 PM
Alindqu1's Avatar
it says on the FAQ that the biggest tire you can put on a stock 2gen 4runner is 32X11.5. it says you may have power loss how likely is it that you will get power loss? I was thinking about liftin it but i think i am going to just get tires and don't want to get anything that will reduce the performance any suggestions would be nice
Old 02-20-2008, 08:12 PM
NwRunner's Avatar
are your running a 4cyl or a 6cyl?
The biggest difference will be gas mileage. Your not gunna have trouble going anywhere, but your not gunna be in the fast lane on the freeway.
Old 02-20-2008, 08:14 PM
22R-to-5VZFE's Avatar
I one word yes...that tire size will be heavier. It may not even be noticable depending on what your running currently. If you lift it too, then your power goes down evern more.
Old 02-20-2008, 08:16 PM
Alindqu1's Avatar
its a 6cyl
Old 02-20-2008, 08:17 PM
NwRunner's Avatar
a 6cyl wont have as much of a problem as a 4, but mainly its your mileage.
As long as your willing to make that sacrifice at the pump, you should be fine.
Old 02-20-2008, 08:20 PM
Alindqu1's Avatar
any recommendations on tires? and if i do get the 32s they fit on the 15in wheels right? would this be a wise choice?
Old 02-20-2008, 08:33 PM
NwRunner's Avatar
personally i would get 31/10.50/15s. Are you planning on running an agressive all terrain or a mud terrain?
Old 02-20-2008, 08:35 PM
olharleyman's Avatar
BF Goodrich KO'S great mileage out of them Good in most conditions , but mud is a different story if you want mud traction then BFG KM'S.
Size wise 31 x 10.5 x 15 is where you will see the least amount of negative effects if you don't lift it
if you do lift it you can go all kinds of different directions depending on how hi you lift it then you also need to consider re gearing if you go to big.
Old 02-20-2008, 08:40 PM
Alindqu1's Avatar
i was lookin at all terains
Old 02-20-2008, 08:42 PM
NwRunner's Avatar
BFG has an impressive all-terrain tire.
Ive also heard (but never used) good things about the Nitto TerraGrapler AT or something like that.
Old 02-20-2008, 08:46 PM
Alindqu1's Avatar
does goodyear have anything thats decent??
Old 02-21-2008, 12:00 AM
taikowaza's Avatar
Bfg
BFG A/T K/O look and wear great. I had 32x11.5x15 on stock wheels with 4.56 ratio manual transmission and it was nice, (31" is WAY too small) but the optimal size for daily driver AND wheeling is 33x10.5 and a 4.88 ratio.
this is assuming you have a manual transmission, if it's auto it sucks you should sell it now and get a real truck
Old 02-21-2008, 12:06 AM
stormin94's Avatar
you could fit some 33-12.50's under there with little to no problems with rubbing, but if I was you, I'd start out with some 31-10.50's. They won't sacrifice power, or economy like the 33's will. And if you don't like those, the good news is, that tires will wear out eventually...which ironically, is bad news for me, because I can't afford new tires right now.
Old 02-21-2008, 09:11 PM
Alindqu1's Avatar
if i did put the 32s on there would i have to modify it at all? or could i just throw them on there?? yeah i have a manual transmission haha
Old 02-21-2008, 10:24 PM
stormin94's Avatar
You could run 33's without any mods, so I don't see why you couldn't run 32's
Old 02-21-2008, 10:43 PM
Matt16's Avatar
With a 22RE, 31's and stock 4.11 gears, the engine bogs down off the line and doesn't like to run at 30mph. Its too slow for 3rd gear and too fast for second. If you're going from 28's, you will notice it for sure.
I test drove a bunch of v6 4Runners all with 31's and they all felt a little slow. I then tried a 3vze with 28's and it was a rocket in comparison.
Old 02-21-2008, 10:55 PM
stormin94's Avatar
Well, the V6 4Runners are a little on the slow side, but it's like a hot rod compared to the 22RE 4Runners. I've never driven a V6 4RNR with 28's but I can imagine it would have quite a bit more pep than 31's.
BushPig
10-29-2022 06:26 AM
06-01-2021 01:51 PM
djpg2000
11-11-2020 04:56 AM
DrZero
18
07-24-2015 11:31 PM
Quick Reply: tire and power question
