timing issue?
timing issue?
94 4runner v6... im getting a very bad misfire. no CEL. did a complete rebuild, major tune-up w/ all new parts, denso and ngk to name a few. its been running a couple months till this morning the misfiring kept me from driving to work so i got out the timing light and found that my timing was retarted. jumpered it with a paperclip and set it back to 10btdc,... still misfiring. i did notice that there wasnt any change in idle speed as i jumpered it w/ the paperclip... gonna do a compression check when i have time. in the mean time, any suggestions out there.... please help, thanks
The TPS would throw a code if it was needing adjusted or replaced.
The FSM troubleshooting page states under Poor idling\Misfire:
1.Fuel quality
2.EGR system
3.Spark plug
4.Ignition circuit
5.Distributor
6.Engine coolant temp sensor
7.Compression
Check 1-4 before assuming it's a timing/distributor issue and then check 5-6 before assuming it's a compression issue.
1.Fuel quality
2.EGR system
3.Spark plug
4.Ignition circuit
5.Distributor
7.Compression
Regency
20
01-03-2020 07:43 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
