Timing difference between 93 & 91
I have a 93 pickup 3.0 v6 I've been stumped with. I bought another engine for it. It is out of a 91 model. Is there any differences in the timing setups with the idler pulleys?
I jst figured that out. Thank you tho. Do you know if the belts are different lengths and a diagram on how it is routed. I've been stumped for 3 hrs straight on this thing.
i have put 2 links here one is for the fsm for most toyotas, and the other is directly to the timing belt and how it all goes,
http://www.ncttora.com/fsm/index.html
http://www.ncttora.com/fsm/1990-1995...e/timingbe.pdf
mine has the spring and the spring goes from the pulley on the passenger side to a hook on the top of the water pump i just had mine all apart but i didn't take any pics i think ill look to make sure,
Ok so I don't have anywhere on my water pump to hook it. But I did get it put on and my belt put on and close. Still gotta tinker a bit. Any ideas on tension?
there is a bolt right above the roller or next to it on the side close to the pulley that the spring goes to, that a bracket bolts to and the spring will pull off the pulley to that bracket
u need to upload them into photobucket.com then use the link from there to the thing that looks like a stamp when u are replying, put the link in there and post it. the pic will show.
