timing cover write-up?
Old 06-05-2011, 01:40 PM
BigSwole's Avatar
Does anyone know of a good timing cover write up?
All I was able to find was headgasket and timing chain and since I'm on my blackberry its hard to go through hundreds of pictures that don't apply to what in doing.
Usually I would just dive right in but I read something somewhere about the top of the timing cover attaching to the headgasket and if your not careful it'll tear the headgasket anf I really don't want that to happen.
Help if you can please! Many thanks!
Old 06-05-2011, 01:46 PM
yoterr's Avatar
yeah its pretty hard to squeez ur timing cover on inbetween ur head and ur oil pan... i messed up my head gasket and my oil pan ended up leaking..lol so i had to take them both off anyways...i think i have pics of what i did on here not sure..
Old 06-05-2011, 01:57 PM
irab88's Avatar
search around a bit.
this one's mine:
https://www.yotatech.com/forums/f116...d-pics-232381/
this one's not mine:
https://www.yotatech.com/forums/f116...cement-212688/
(lots o' pics)
Old 06-05-2011, 02:11 PM
waskillywabbit's Avatar
www.ncttora.com/fsm
:wabbit2:
Old 06-07-2011, 02:58 AM
92 TOY's Avatar
this one's mine:
(lots o' pics)
that 2nd one is pretty good I've heard
Old 06-07-2011, 04:20 AM
xxxtreme22r's Avatar
the reason why you keep coming up with headgasket threads with timing cover/chain replacement, it because technically it's supposed to be done with the head and oil pan off.
I did mine with the head on, however, because I tried to do mine in almost complete darkness I messed up the part of the headgasket between the head and timing cover and it leaked for months till I had to rebuild my entire motor because of a spun rod bearing. (had nothing to do with running the truck low on oil BTW)
icentropy
09-16-2020 02:47 PM
smiley52
07-11-2015 05:16 AM
icentropy
07-09-2015 02:12 PM
Quick Reply: timing cover write-up?
