Timing Chain Problems
Old 02-01-2011, 02:20 PM
22repower's Avatar
Just installed a new timing chain in my 22re
It started right up, sounded fine for about five seconds, then started rattling just like it did when the chain was worn out
Let it run for about 5 minutes and the noise never went away
After this I pulled the my valve cover off, everything still looked right
Anyone have any ideas what could be the cause...?
Old 02-01-2011, 02:32 PM
xxxtreme22r's Avatar
Valve lash, rod bearing, flat camshaft, piston slap, engine fan hitting shroud, EGR making noise, injectors all come to mind. I CANNOT STRESS ENOUGH, it is IMPOSSIBLE to diagnose a weird sound looking at black and white type.
So many people do this and I do not know why it is so hard to understand that you will be just chasing nonsense for no reason wasting your time and others time without a VIDEO.
Noob or not, it's just COMMON SENSE.
I think the mods need to start making it mandatory for people to post up VIDEOS when someone wants an engine sound diagnosed or the thread gets deleted.
Old 02-01-2011, 02:39 PM
22repower's Avatar
Right now I'm assuming that the noise is the timing chain
Old 02-01-2011, 02:48 PM
right now I am assuming it's a rod bearing. Tear apart the motor put it back together I bet you I am 99% right in saying your noise will go away. The other 1% says it's your everyday 22re tick.
Old 02-01-2011, 08:01 PM
totally a bro
Staff
vital22re's Avatar
Tensioner may be shot you may have used too longof a bolt for the oil pump and it's pinching the tensioner. But without hearing it or any other details I'm gonna say you have a rattle snake in the timing cover. It's pretty common.
Old 02-02-2011, 11:26 AM
22repower's Avatar
Ended up being the idler pulley
Sorry for no video, don't have a sound recorder
Old 02-02-2011, 11:39 AM
fierohink's Avatar
^^^I think that make XXX's point exactly. The OP says his truck is making noise, Help Me!!!
Is it internal or external to the motor? Top end or bottom end? RPM dependent, constant, or whatever? One man's tap is another man's worst nightmare. We can't help you without more information.
This goes for EVERYBODY.
jennygirl
11-17-2015 11:24 AM
fasterspider
10-06-2015 10:24 AM
Ichneumon
09-27-2015 04:21 PM
paxanders
06-21-2015 06:29 AM
Quick Reply: Timing Chain Problems
