YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 11-25-2007, 09:46 AM   #1 (permalink)
Personal Sales Rating: (0)
Timing Chain / Engine Noise A Reflection
Well i buttoned up the 4runner and drove it around. It is running nice, but it seems i have lost a little power. But all in all this is what i found out.
Before tearing the motor compeltely apart check a few more things.
I had the dieseling noise when i started the motor up. I pulled the timing chain and it and the guides looked real new ,and there was no evidence of the chain slapping on the timing cover. So i changed the chain out and sealed it up. I now know it takes to tear into a 22RE. I now know the age of the timing chain and hopefully i get rid of the oil leak in the front of the motor.
When timing the engine i now know i have either a broken or dirty TPS. I Ohm'ed it out today and i get nothing between the IDL and E2. No resistance at all. So i guess that is one reason why the jumper on the diagnostic port does nothing to change timing.
I also found out the diesel noise was not the timing chain. It turns out the idle RPM was set really high on the motor. I dont have the tach on the motor so it really didnt sound that high. But when i put my tach/dwell meter on it, the motor was idling at abotu 1300 rpm when it was even warmed up. So i knocked it down and retimed the motor to 750rpm. When i start it up i do not get that sound anymore. Even after i let it set and get cold overnight. But the idle is slightly irratic, it will pulse from 750-800 . Not that bad, but i can notice it a touch.
So all in all the truck runs good, but it seemed to be a little less peppy compared to before i opened it up. So i think it is possible the timing being setback to normal makes it a bit sluggish cause i am used to the timing advanced a bit.
So all in all i am happy and dissapointed but in the end i have it together and running. So I will address the TPS in a week or so, i am tired and it is getting chilly otuside.
Thanks for all the help!!
__________________
Dan Stewart
1989 4Runner
1963 M38a1
1991 Wrangler
DanStew is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 11-25-2007, 10:11 AM   #2 (permalink)
SoCal4Running's Avatar
Quote:
+1
Why not advance it up a little more. I belive on mine stock is 5 deg but it runs way better at 8 to 9 deg. I only set it a 5 for smog checks then back up it goes.
__________________
'86 4runner
22RE, 5-speed, LC Street EFI head w/ cam, LC Pistons, ARP Head Studs, Downey header, Dynomax 2 1/4" full exhaust, VDO water temp guage, ASIN manual hubs, 01-03 Tacoma cd\tape radio with 10" Bazzoka, Downey 2" rear springs, GDI radiator. Back to daily driving duties
'68 Ford Mustang Fastback
Daily driver with a built 289 and a streetfighter trans.(Retired)
98 Subaru Outback-For Sale
2005 Toyota Tacoma
V6, 6 speed stick, Speedway Blue
Waco93.com
SoCal4Running is offline
Old 11-25-2007, 10:20 AM   #3 (permalink)
Threadstarter [OP]
I am not so much looking for pwoer, but more MPG, i may tweak it a touch after i see what i am getting for milage like this.
__________________
Dan Stewart
1989 4Runner
1963 M38a1
1991 Wrangler
DanStew is offline
Old 11-25-2007, 03:08 PM   #4 (permalink)
It isn't going to run right until you get a new TPS or figure out why it isn’t working correctly.
84sr5yoty is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
2005, 2007, 99, chaene, chain, engine, enginecom, noise, noises, noisy, rid, sound, tacoma, timing, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
New engine noise (not valve tap or chain rattle) toymotaman 86-95 Trucks & 4Runners 7 02-18-2006 07:34 AM
OH OH I Broke it GOOD engine no Workie, Timing Chain ? 4Hummer 95.5-2004 Tacomas & 96-2002 4Runners 40 11-14-2005 09:07 AM
22re timing chain/set timing/rtv/headremoval brendonv 86-95 Trucks & 4Runners 4 09-20-2005 06:18 AM
Noise coming from engine: timing chain? Nolan 95.5-2004 Tacomas & 96-2002 4Runners 9 09-11-2005 09:10 AM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
