timing chain cover problem - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Sign in using an external account
Register Forgot Password?
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 02-21-2012, 01:23 PM   #1 (permalink)
Personal Sales Rating: (0)
topher.91's Avatar
so while changing out my timing chain i was put on the cover and broke the head gasket!!!!!! Now my question is this is it ok to RTV gasket just that part of the HG or should i pull the head and replace the whole HG. i know i know i should replace it but i need my truck running sooner than later and dont have much time cuz i am working or going to school 6 days a week. my truck is a 1991 22re.
__________________
1994 4runner - totaled
1991 pick up, 22re, 4 in lift, 33x12.50x15s, lock right up front and much more to come.
topher.91 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 02-21-2012, 01:46 PM   #2 (permalink)
swampfox's Avatar
clean everything really well ,coat the remaining gasket and surfaces with a light coat of silicon and drop the oil pan enough to install the timing cover . I did it this way on a truck that the po had bent the gasket inward and after 3000 mi no leaks. If it already in stalled you might try cleaning the gap and squeezing silicon in the gap.
__________________
89 reg cab 2wd 22r 5 spd
89 reg cab 4wd 22re 5 spd
swampfox is offline
Old 02-21-2012, 01:59 PM   #3 (permalink)
Smoov-E23
I'm not familiar with the 22RE but how did the head gasket break? Does it stick out from the head?
ee23 is offline
Old 02-21-2012, 02:06 PM   #4 (permalink)
Threadstarter [OP]
topher.91's Avatar
yeah i am just concerned that the silicone gasket will blow under that amount of pressure or is there not enough pressure in that part of the eninge.
and yes in the 22re the HG sticks out over the timing chain cover.
__________________
Old 02-21-2012, 02:12 PM   #5 (permalink)
jkent's Avatar
I used a gasket sealer called "The Right Stuff" it worked great! I eventually went back and replaced the head gasket but it held up for awhile till I had the time to do it right.
jkent is offline
Old 02-21-2012, 02:35 PM   #6 (permalink)
Threadstarter [OP]
topher.91's Avatar
was it just for DDing or where you high RPM reving and wheeling too? i have the red RTV and it says its for high pressure and high temp. has anyone heard or used this stuff.
http://www.steelseal.net/
__________________
Old 02-21-2012, 02:47 PM   #7 (permalink)
jkent's Avatar
the right stuff worked pretty good but it still leaked under the distributor area. I tried a few times to stop it but said the hell with it and just replaced the head gasket. I recommend getting a timing chain gasket and seal for the dealership to.
mostly trail riding and hunting no mudding..to answer your question
jkent is offline
Old 02-21-2012, 02:49 PM   #8 (permalink)
Threadstarter [OP]
topher.91's Avatar
ok. yea i have the gaskets from LCE because i did there metal chain guides. OEM from the dealership are better? probablly pricey though right.
__________________
Old 02-21-2012, 02:57 PM   #9 (permalink)
When in doubt, drink heavily!
Personal Sales Rating: (9)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
Quote:
This is not the proper way, nor even a good way to fix this issue
Quote:
Yes, the gasket sticks out over the timing cover and spaces the head off the timing cover
Blow out isn't that you need to be concerned with.
Quote:
Still not a good idea
THIS is the proper way to do it.
If you do not replace the headgasket, you can/will crack the timing cover where the "hidden" bolt goes in. The head gasket acts as a sort of spacer that will not completely crush down or squeeze out the sides. If you just use silicone, the silicone will squeeze out the sides and allows the head to pull up on the timing cover via the hidden bolt. This eventually cracks the timing cover after even a short service interval.
Long and short, if you want the engine to last more than a few thousand miles, replace the head gasket. Sure it sucks doing the extra work, but it sucks even more when you have to replace the engine because of a cracked timing cover.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by BigBluePile View Post
Hmmm, dunno. Ask the oem Nazi DC.
Quote:
Originally Posted by waskillywabbit View Post
Dare I say this...but I agree with MudHippy.
DeathCougar is offline
Old 02-21-2012, 02:57 PM   #10 (permalink)
Staff
OEM gaskets are always better with the 22RE. Compare gaskets side by side, and you will see the quality difference
__________________
Old 02-21-2012, 02:57 PM   #11 (permalink)
jkent's Avatar
I used the LCE gaskets the first time thru and went with the dealership ones the next time..I saw a big difference between the two. I would have to look for the receipt but I think it was double the amount of the local car parts store. worth the price to me. I used the black gasket sealer the first time and the right stuff the second time and the right stuff worked a lot better...messy but better imo
jkent is offline
Old 02-21-2012, 03:08 PM   #12 (permalink)
jkent's Avatar
Quote:
Very true DeathCougar! ...Learned that lesson the hard way! doh!
jkent is offline
Old 02-21-2012, 04:04 PM   #13 (permalink)
cman1's Avatar
if you just try to seal it ...you WILL be taking it apart again sooner or later.probably sooner.
__________________
work sucks...period!
cman1 is offline
Old 02-21-2012, 04:11 PM   #14 (permalink)
Threadstarter [OP]
topher.91's Avatar
very true thank you for all your imput looks like i get to do it the right way and since i am in there i get a new cam =] stoked but not at the same time hahha
__________________
Old 02-21-2012, 05:03 PM   #15 (permalink)
cman1's Avatar
im a big fan of engnbldr kits,i did the whole timing cover head gasket back in november.
__________________
cman1 is offline
Old 02-21-2012, 05:08 PM   #16 (permalink)
swampfox's Avatar
Deathcougar is right in saying my way is not correct , the way I suggested worked for me because the front of the head gasket was there and it was new just shoved back ,and it kept the timing cover from getting hurt. I had not considered the hidden bolt when I suggested using silicon only.
__________________
swampfox is offline
Old 02-21-2012, 05:11 PM   #17 (permalink)
Threadstarter [OP]
topher.91's Avatar
yeah the front of my HG is in peices hahahah.yyeah i am most deffenitly doing the Engnblder cam GREAT prices and i hear lots of great reveiws.
__________________
Old 02-21-2012, 05:39 PM   #18 (permalink)
angrybob's Avatar
Mystery Possibly Solved
Reading the above, I think I just twitched.
When I bought my 4Runner about two years ago, it came with a full engnbldr timing chain kit. It was my first venture into auto engines in many years.
I chose to leave the head on since the HG was fairly new. Problem was I got ahead of myself during reassembly and installed the oil pan before the timing cover. Needless to say, I FUBAR'd the front part of the HG trying to sandwich the timing cover between the head and the oil pan.
I decided to try and make it work because I didn't want to spend the time on replacing the HG. I cut out the part that stuck out from the head and tried to use FIPG. Didn't work. In addition, I also managed to put a small crack in the timing cover when I snugged the hidden head bolt with a 1/4" drive.
[Until now I had no idea how that could have happened. I know I did not gorilla the torque on that bolt. Now, I probably know - thanks DeathCougar]
In short, there were many leaks and I got to do it all over again including the HG. I did it right the second time (of course) and put the oil pan on last. I followed 4crawler.com instructions and it was easy from there.
No oil leaks in about two years.
For me, no harm was done since its not a DD. I lost some time and sweat equity but from that point, I've been anal about fixing and improving things the right way.
__________________
'87 4Runner
Weekend Warrior Trail Duty
Built not Bought
angrybob is offline
Old 02-21-2012, 11:12 PM   #19 (permalink)
Threadstarter [OP]
topher.91's Avatar
angrybob- this is exactly why i asked this question brofor i did something stupid. so taking you and Deathcougars advise i am going to do it right the first time and rebuilding the cam so i can have a good engine i can depend on for years to come. thank you to all of you as i am still a youngun and dont want to make stupid mistakes as i want to keep this truck and pass it on to my kids.
I <3 YOTATECH!!!!!!!!!!!!
__________________
Old 02-22-2012, 09:09 AM   #20 (permalink)
Personal Sales Rating: (3)
Grego92's Avatar
Have fun!
I was in the exact same position you are in...change or not to change HG. After I mucked something up I took the advice of others and did a full HG change and then some! no regrets at all and it has been a great learning experience for me.
My initial dilemma from about 6 months ago...http://www.yotatech.com/f116/22re-hg...-chain-240066/
And today! almost done....I used all oem supplier or toyota parts from Wabfab, Toyota, 22re.com, Amazon, etc...but used an engnbldr cam/metal timing guide rail and LCE header. (FYI - I'm selling my timing cover, oil pump, and timing kit from engnbldr if interested! minus the driver steel guide rail...I decided to go oem)
Grego92 is offline
Old 02-22-2012, 08:14 PM   #21 (permalink)
Threadstarter [OP]
topher.91's Avatar
Grego92 that eninge bay is clean!!!!!! i would but i just got my timing kit. thank you for the offer though. how do you like the LCE header? i am trying to figure out witch one to get. did your header turn 134134 different colors or nice and shiny?
__________________
Old 02-22-2012, 09:30 PM   #22 (permalink)
Grego92's Avatar
Thanks, yours will be too, if a first timer like me can do it anyone can. If u break or mess up a piece of your kit, hit me up, I'm in south cali so shipping shouldn't be much. I have no idea about the header yet! I'm not finish with my build. There are a number of positive reviews though. Good luck and have fun during your build, my advice is take your time and don't cut corners.
Grego92 is offline
Old 03-14-2012, 11:21 PM   #23 (permalink)
Threadstarter [OP]
topher.91's Avatar
well everything is together. have a little coolant leak issue that i am still trying to find might just throw some coolant sealer and see if that works. and i just ordered new headers and i am going to pick up some intake stuff cuz in intake tube ripped as i was taking it off. post pics when i get the new headers on.
__________________
Old 03-15-2012, 08:05 AM   #24 (permalink)
angrybob's Avatar
Do you know the origin on the leak?
just curious - did you replace the water pump/shaft seal or reuse your current one?
__________________
'87 4Runner
Built not Bought
angrybob is offline
Old 03-15-2012, 10:53 AM   #25 (permalink)
Threadstarter [OP]
topher.91's Avatar
i cant see where its leaking from but i thin its somewhere near the waterpump but i replaced the water pump and everything has fresh gaskets on it. i felt around down there to see if i could feel it but couldent. anyone know of any good sealer that would do the job instead of pulling my pullys again?
__________________
Yotatech
4WD Truck
Paid Advertisement
Tags
1991, 22, 22r, 22re, 91, break, broke, chain, changing, cover, gasket, motor, reuse, rtv, safe, timechain, timing, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Contact Us - YotaTech - Archive - Top
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
2010 InternetBrands, Inc.
