Timing Chain Cover Cracked
Just changed my timing chain on my 22re 4runner. When tightening the hidden head to timing chain cover bolt, I cracked the timing chain cover. I suspect that it is because of the gap between the cover and head. Does anyone use anything other than RTV to seal this? I think I am going to make a gasket out of gasket material to take up the gap. I hope I don't crack my new timing chain cover.
Staff
I wonder if you got the correct timing cover. 84 and older covers are different from the 85 and newer. Never run into cracking a cover. Seems like I have heard of people stripping the bolt hole out from over tightening.
Gap? I did not have a gap.
Do you have any pics?
I did bust a bolt head off. But i said screw it and put washers under the ac bracket to put pressure on that spot. 75 miles so far and about 1/2 tanks idling. So fat no leaks that I can tell.
I used Ultra Gray for the whole job.
I already had the head on and torqued down. So it was a choice between leaving it or choosing my leak spot the head or the bolt. So far no leaks.
Where the bolt is / Shows the broken bolts spot.
gibbonsballer10
10-26-2023 07:13 AM
voiddweller
53
02-01-2016 05:46 AM
