Timing a 22RE - YotaTech Forums
Go Back   >
Timing a 22RE
LinkBack Thread Tools Search this Thread
Old 10-26-2008, 05:04 AM   #1
Timing a 22RE
I just did the head gasket on my 94 Toyota and set the timing chain and everything right, but now i need to put the distributor back in and don't know how to set it at base timing and also need to know the firing order on the distributor and on the motor. Thanks for the help.
clayton_CJ7 is offline   Reply With Quote
Old 10-26-2008, 05:45 AM   #2
baseballchamp157's Avatar
Im pretty sure the firing order is 1-3-4-2. But im looking forward to this thread to because i could learn a little more about timing. Plus whats funny is i just did the same thang and i have a 94 yota p/u
baseballchamp157 is offline   Reply With Quote
Old 10-26-2008, 01:12 PM   #3
Anyone have any suggestions, the guy that was going to help me bailed.
Old 10-26-2008, 01:45 PM   #4
TOYOTA 1's Avatar
firing order is as baseball said 1342.
now bring up #1 piston @TDC on compression stroke!
then make sure that the harmonic balancer pulley mark is lined up with the 0 degree mark on the timing number tab. then put the distributer in with the rotor pointing at the #1 plug wire on the cap!
TOYOTA 1 is offline   Reply With Quote
Old 10-26-2008, 03:25 PM   #5
ok yea, that sounds right. I remember doin that. and you know that the #1 piston is at TDC by puting a screw driver in the #1 piston spot by taking out the spark plug. Then turn the pully untill it hits.
Old 10-26-2008, 04:57 PM   #6
Cool, i already have the motor at tdc and all that i just needed to know how to put the distributor in and how the wires go. So my only other question is which one is 1 on the cap and what is the firing order on cap and block? Thanks.
Old 10-26-2008, 05:55 PM   #7
TOYOTA 1's Avatar
Quote:
lol the pistons are 1234 from front to back.
the firing order on the cap is 1342.
number one on the cap should be marked.
similar to this one http://www.theautochannel.com/autopa..._65962bvx.html
Old 10-26-2008, 06:25 PM   #8
abecedarian's Avatar
typically, when the distributor is installed, #1 ends up at about a 45 angle up and towards the front of the vehicle. then the other cylinders connect in a clockwise rotation around the distributor
so if you imagine the terminals on the cap make a square, #1 is top left, #3 is top right, #4 is bottom right, #2 is bottom left.
abecedarian is offline   Reply With Quote
Old 10-26-2008, 07:03 PM   #9
misterzee's Avatar
... did you get your head bolt torque pattern and specs from another thread?
misterzee is offline   Reply With Quote
Old 10-26-2008, 07:15 PM   #10
rdlsz24's Avatar
Get it at TDC on compression stroke. Push the distributer in with the rotor at 12 o'clock and it will rotate counter clockwise a bit. This will get you close enough to start it and set the timing using a timing light.
Rob
rdlsz24 is offline   Reply With Quote
Old 10-27-2008, 01:57 PM   #11
Yeah i got my torque specs from there, thanks guys. And i knew the block was 1234, sorry
88 Pickup Transmission Swap mskalmus 86-95 Trucks & 4Runners 6 03-21-2016 12:41 PM
1985 re engine wiring steve miller General Electrical & Lighting Related Topics 2 10-10-2015 02:40 AM
94' Pickup ZUK Mod - What Springs? Nickdigg 86-95 Trucks & 4Runners 1 07-07-2015 07:04 AM
1985 22re a/c install help bryan34w 84-85 Trucks & 4Runners 0 07-06-2015 06:53 PM
Tags
1986, 22, 22re, 83, 92, 94, base, clockwise, distributer, distributor, firing, order, rotation, set, timing, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
