timing
Old 10-24-2009, 01:35 PM
jlodge's Avatar
timing
Hi,
I just built up a 22re on an 89 4 runner. It runs... Just rechecked the timing chain, sprockets lined up, looks good. When I place the distributor holding bolts in the center the timing is way out in 20 degrees or something. The distributor bottom out a 5 degrees no less. Any suggestions on how I can get the range from 15 to zero or below? Thank you James
Old 10-24-2009, 01:48 PM
Kiroshu's Avatar
Welcome to yota tech! Are you sure you marked the crank in the correct spot? This is a common error when checking timing. Make sure the distributor is in correctly.
Old 10-24-2009, 02:02 PM
abecedarian's Avatar
Also, are you jumpering the TE1 & E1 terminals in the diagnostic plug when checking timing and idle is about 750?
Old 10-24-2009, 02:23 PM
jlodge's Avatar
Wink
Hi thanks for the replies... I'll get a picture of my 89 stock runner up. What do you mean by lining the crank up correctly? I'll take all the advice I can get and I'll give some in return. Happy 4 running...
Old 10-24-2009, 02:27 PM
jlodge's Avatar
Oh I see what you're saying about the crank, ya I think it's at tdc when the mark hits zero... I'll go double check on both...thanks
Old 10-24-2009, 02:33 PM
Kiroshu's Avatar
Yea just make sure its marked on the correct notch. I had 2 or three notches in my crank pulley for somereason and then i finally marked the right one.
Old 10-24-2009, 02:46 PM
My 88 and 91 have 0, 5, 8 and 12 degree marks on the pulley.
Eggslinger
06-08-2019 03:32 PM
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
smiley52
07-11-2015 05:16 AM
Quick Reply: timing
