time for a new driveshaft? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-03-2009, 08:56 AM   #1 (permalink)
Beaniam's Avatar
Send a message via AIM to Beaniam
Since the SAS and lift I noticed a weird driveline vibration around 20mph and sort of a rattle/woosh sound when letting off the throttle at around 40-50mph.
Checked the driveshaft today and the ujoint caps are loose inside the driveshaft ears up at the transfer case. These have been like that since I replaced the u-joints but I didn't really think much of it. Now with the increased angle it's an annoyance.
I'm assuming these are supposed to be pressed in tight unable to move right? The ujoint is less than 4 months old but the old one had become so bad the caps were seized to the ujoint and were spinning inside of the driveshaft ears instead of on the bearings. If there any way I can tighten it back up again? Tack welds? Or just find a junkyard driveshaft?
__________________
1993 Pickup
Aussies front/rear
5.29's
SAS 85 axle trussed and gussetted w/ HP third
30 spline longfields
Trailgear IFS Eliminator 5"HD springs
Rear 4" springs
37"x13" Boggers
4crawler 1" body lift
Snorkel
Warn Rockcrawler bumper
Smittybilt rear bumper with some major reinforcing and recovery points
4xinnovations tube doors
Champion 7500lb winch
2.5" Magnaflow exhaust
Stacked through the bed
Beaniam is offline
Old 01-03-2009, 09:04 AM   #2 (permalink)
dbcx's Avatar
Havent ever had that happen before. I bet it did make some crazy noises if the cap was spinning inside the ends.They are pressed, not sure what you could do to tighten it back up without getting a new shaft. Is it a daily driver?
__________________
1997 4runner. stock for now just got it
1999 z71, intake ,285bfgs,with ford keys,hypertech
1974 baja bug 2110cc dual weber 40s,rancho tranny
www.lubedealer.com/dbcox ZO#1568374
Click for free catalog:https://www.amsoil.com/AmsoilLogin/L...x?type=catalog
dbcx is offline
Old 01-03-2009, 09:06 AM   #3 (permalink)
algranger's Avatar
if the cap was spinning it probly wore down on the dshaft pretty good. id go get a new one at the junker and use your old ujoint
__________________
I said lie, for me
lying under a process tree
algranger is offline
Old 01-03-2009, 09:15 AM   #4 (permalink)
Beaniam's Avatar
yeah that's what I figured. It's not my daily. I'll pick up another driveshaft and experiment with a couple light tack welds to hold this one in place for the time being
__________________
1993 Pickup
Aussies front/rear
5.29's
Rear 4" springs
37"x13" Boggers
Snorkel
Beaniam is offline
Old 01-03-2009, 10:47 AM   #5 (permalink)
yota4runna's Avatar
Quote:
Originally Posted by Beaniam View Post
...... If there any way I can tighten it back up again?....
Yes, even though the u-joint cap has spun inside the eye and has worn away some material, it can be tightened up. I learned this at a local driveline shop. You first take the u-joint out of the eye. Then you heat up the enlarged eye with an oxy-acetylene torch until it's red hot. Let it slowly air cool - don't quench to cool it. It will now be a press fit again.
yota4runna is offline
Old 01-03-2009, 12:00 PM   #6 (permalink)
Beaniam's Avatar
hmm... didn't think of that. thanks for that tip. I used a punch and peaned some of the inside of the ears then the caps pressed in tightly.
__________________
1993 Pickup
Aussies front/rear
5.29's
Rear 4" springs
37"x13" Boggers
Snorkel
Beaniam is offline
Old 01-03-2009, 09:16 PM   #7 (permalink)
Beaniam's Avatar
You know what I just realized today after 2 years which was pointed out by the guy I picked up a new driveshaft from today? Mine is on backwards. Slipyoke is by the 3rd member and the solid section is up by the transfer case. I don't know if that really matters but I'll switch it back around when I put the new one in.
__________________
1993 Pickup
Aussies front/rear
5.29's
Rear 4" springs
37"x13" Boggers
Snorkel
Beaniam is offline
Tags
4runner, 87, cap, spinning, ujoint, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Why does the FJ Come in part time and full time 4wd? Fo by Fo FJ Cruiser 13 10-13-2008 10:56 AM
long time lurker first time poster kayakken Introductions & New Arrivals 0 08-10-2007 11:20 PM
(3rd Gen) 4Runner - 4WD all the time or 2WD part of the time? Galen 95.5-2004 Tacomas & 96-2002 4Runners 12 01-19-2007 04:49 PM
part time job + full time student = cant afford gas gtm130 95.5-2004 Tacomas & 96-2002 4Runners 8 07-28-2004 08:34 PM
Hello! New to board, long time listener, first time caller. Ducseven 95.5-2004 Tacomas & 96-2002 4Runners 6 03-15-2004 04:22 PM
2009 InternetBrands, Inc.
