Throttle sticking at idle
Old 08-14-2011, 08:18 AM
BUST'EM504's Avatar
My throttle is sticking at low rpm but I can pull the pedal back and it will drop the rpms back down. Any easy fixes for this??
Old 08-14-2011, 08:57 AM
T_F_E's Avatar
spray wd 40 in the throttle cable
Old 08-14-2011, 09:12 AM
SCToy's Avatar
This happens in my 81 and I can see the throttle return spring is weak that is next to the carb. Haven't figured out a solution as the dealer does not list the part number at all.
Old 08-14-2011, 09:14 AM
xxxtreme22r's Avatar
22r or 22re? mine kinda sticks because the cable itself is frayed a little and as mentioned above the return springs really wore out. Mine's a carb'd 22r with a weber. Rigging a return spring solved most of my issues, might not be as simple to do on a 22re though.
Old 08-14-2011, 09:24 AM
BUST'EM504's Avatar
It's a 22 re I tried to play with the spring by the pedal but that didn't help. I will try the wd 40 and see what happens
Old 08-14-2011, 09:30 AM
not just the spring at the pedal but on the throttle body as well.
Old 08-14-2011, 09:40 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Go ahead and spray the WD40 on whatever, but I'd disconnect the throttle cable from the throttle body linkage and atleast try to pinpoint what's hanging up. I mean, it could be the throttle plate itself, but you wouldn't see it if you hadn't looked in there or cleaned it in a while.
Old 08-14-2011, 11:10 AM
BUST'EM504's Avatar
Thanks guys I'm going to go pull some stuff apart when it cools off a bit
Old 08-14-2011, 02:36 PM
peow130's Avatar
pull the cable out, and spray some carb-cleaner into the cable itself to clean out the garbage..
I did this, and it came out black on the other end.
Next, go buy some white-lithium grease and lube up your cable.
Blamalam
03-12-2022 07:34 AM
Alex Bessinger
08-31-2015 09:17 AM
mtc1105
08-04-2015 08:06 PM
bighaydn
08-04-2015 07:17 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: Throttle sticking at idle
