Throttle sticking!!!! DANGEROUS!
Throttle has been sticking lately and I am assuming it's the cable binding. Anyone ever had this happen to them? Where do I get a new cable from? been looking for a new one for about 3 hours now online and cannot find one! Anything else it could be?
Thanks
Woody
Thanks
Woody
Just was going to try to lube the cable itself when I came upon this, my linkage in my weber seems to be what is sticking I think. Here's the video:
http://youtu.be/MIxCDSsPkJg
What do I do now?
What do I do now?
Last edited by woodyth; 02-28-2012 at 01:36 PM. Reason: trying to get video to work
http://www.warp-central.com/crazy_ha...ebber_jam1.jpg
http://www.warp-central.com/crazy_ha...ebber_jam2.jpg
Check the areas circled in red for binding.
I noticed that when I simulated a stuck 2nd barrel, that it acted like, and sounded like your Webber in the video
i had the same problem with my webber! all i did was go to the parts store and get a return spring. i hooked one side to the linkage and the other to the bottom lip of the filter housing and it worked great. hope it helped
I'd hit those areas with a little wd40.
If that immediately solves the issue, then I would add a bigger return spring like Goodyota said.
If it doesn't solve the issue, then it must be hanging up somewhere else.
