Throttle positioning sensor
Old 12-02-2009, 10:29 AM
maccabadbad's Avatar
I have an 86 4runner and wondered if I could change the tps on my own or do you need to reset anything, has anybody done this before
Old 12-02-2009, 10:40 AM
blue_CA_yota's Avatar
do a quick search, or just skim through the first 3 pages of the board..
Simple change, gotta adjust it after.. only need a multimeter..
search for TPS
Old 12-02-2009, 11:31 AM
a multimeter is what exactly?
Old 12-02-2009, 11:33 AM
jrock's Avatar
TPS for 3rd gen
ive got an extra one for 3rd gen if anyone needs one. replaced it thinking it was preventing ecu from going into open loop. It was not the problem.
Old 12-02-2009, 11:54 AM
sb5walker's Avatar
Measures voltage & resistance, among other things.
http://www.amazon.com/Equus-3320-Aut...dp/B000EVYGZA/
That one has auto-ranging - as a beginner, you should look for one with that feature. Its only $18 with free ship - thats a very good meter at that price.
Old 12-02-2009, 09:25 PM
what would I do with this when I change my TPS sensor
Old 12-02-2009, 10:08 PM
abecedarian's Avatar
well... you would use it to check the TPS adjustment after you put the new one in.
Old 12-02-2009, 10:13 PM
874runnersr5's Avatar
its easier to adjust the tps with the tb off.
Old 12-02-2009, 10:22 PM
Is not.
Get yourself a small 90 degree / right angle phillips screw driver then....
With the engine running, put the jumper in the diagnostic plug, loosen the TPS then rotate the TPS one way until the idle speed jumps up, then rotate it the other way until just when it drops down. If the idle doesn't jump up, forget that and rotate it til the idle drops. You just have to be sure that the idle "just" drops. If you're not sure because things move too much, tighten the screws barely tight enough so you have to 'tap' on the TPS to move it.
That's a lot easier than removing the throttle body, considering you don't have to replace the gasket, loosen vacuum and coolant hoses, etc.
Old 12-02-2009, 10:29 PM
sb5walker's Avatar
The technique you suggest, abe, does sound easier than removing the TB. On the veezy, if you want to use feeler gauges to adjust the tps as directed in the fsm, you really have to remove the TB. Not sure whether that's true with the 4 cyl.
Anyway, the important thing is that IDL & E2 have continuity when throttle is closed, and do not have continuity when its open.
Old 12-02-2009, 10:35 PM
Guess I should add that if the idle doesn't change whichever way you move the TPS, then you have a problem with the TPS and/or the wiring... and maybe the ECU...
or...
... you didn't insert the jumper properly.
Old 12-03-2009, 07:08 AM
its always nice to clean the tb with my method tho haha.
Old 12-12-2009, 08:29 AM
socal_style's Avatar
I tried doing the TPS adjustment the way it is mentioned on the FSM, but I was never able to do it. Finally after reading this thread and reviewing, Abecedarian's method, I was able to set it correctly, and boy what a difference. My truck runs way smoother now.
If I ever get to meet Abecederian, I am going to have to buy you a beer. You helped me out on at least three different occasions, when I was stuck. Thanks for sharing all your information on here!
crammit442
7
11-29-2017 12:30 PM
Dennisx2
08-10-2015 06:48 AM
Dennisx2
08-04-2015 01:26 PM
Steven.m.paulk
07-24-2015 01:44 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: Throttle positioning sensor
