Throttle Body On Vehicle Inspection "question(s)"
Old 04-29-2009, 04:39 PM
WetbehindEars's Avatar
So.. today after a small wiring problem on the igniter, we started the Throttle Body on-vehicle inspection. Did not get far.
Page 1 says to check the 3 vacuum lines on the top of the throttle body. Ports E,R,P
At Idle ports E,R,P should have No Vacuum
At 3500+ RPM ports E,R,P should have Vacuum
Our port R does not have Vacuum at 3500 RPM or higher.
Both ports E & R lead to the EGR modulator.
I checked with low pressure air from where the line plugs into the modulator to the throttle body, and its clean.
Is there any reason that would not be drawing a vacuum at higher RPMs?
Also.... on the next step it says insert a SST between the throttle stop lever and stop screw. Anyone know the diameter of this SST?
smthwsn357
12-04-2023 02:08 AM
06-01-2021 01:51 PM
jasonty
41
12-23-2018 01:00 PM
rushw
07-18-2015 01:46 PM
raiderhawks00
07-08-2015 06:23 PM
Quick Reply: Throttle Body On Vehicle Inspection "question(s)"
