Throttle body gasket.
Old 04-14-2008, 07:12 PM
kmat123's Avatar
I am replacing my idle air control valve tomorrow (thanks to anotherjeff) and will have to pull off my TB to do so. I had it off just a few months ago and replaced the TB gasket at that time, so I was wondering if it is truely necessary that I do so again? The reason I ask is that none of the local autoparts places carry it so I would have to drive out 20 miles to the dealer. Your input would be greatly appreciated!
InternetRoadkill's Avatar
permatex fixes all.
Old 04-14-2008, 07:14 PM
gamerndm's Avatar
if the gasket isnt still in good shape, you could probably get a sheet or 2 of gasket material from any auto part store and cut one yourself, thats what me and a friend did when we rebuilt the carb on his '70 c-10 a few weeks ago
Old 04-14-2008, 07:58 PM
JohnRaven's Avatar
That's what I have done many times...with the same sheet of gasket material!
Sheet of Gasket material = $5
Saving $50 on gaskets....
AWESOME
Its kind of an art to making good gaskets, just takes a little practice and a very sharp razor blade... well worth it!
Old 04-14-2008, 10:24 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Reuse it. I've done it many times. Just torque it down a little tighter. But, be careful it doesn't tear on you.
Old 04-14-2008, 11:40 PM
Matt16's Avatar
Its not like the head gasket, you can re-use it a couple times. When it wears out, use Permatex.
Old 04-15-2008, 02:05 PM
toyotalytrevor's Avatar
and when you truck doesnt run properly cause it has a vaccum leak or sucked peratex down the intake.... fix it properly with a new gasket.
save yourself the headache, fix it once, fix it right.
Old 04-15-2008, 04:10 PM
Matt16's Avatar
I really doubt your going to suck the Peramatex out from betweeen tow machined surfaces and down the intake.
Old 04-15-2008, 05:38 PM
thook's Avatar
Whatever, man. I've reused gaskets like that....if they've not been on too long.....for years. I've NEVER had a problem. And permatex......you'd really have to goop that crap on and just plain not pay attention.
This holy roller junk is just that.
Blamalam
03-12-2022 07:34 AM
jetpilot
08-15-2015 06:48 AM
mtc1105
08-04-2015 08:06 PM
bighaydn
08-04-2015 07:17 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: Throttle body gasket.
