Thread info for clutch master and slave cylinder
Old 12-04-2009, 10:21 AM
broncbob's Avatar
I have to put a new line between the master and slave cylinders on my 89 4x4 pickup with the 22RE. The line that is on it now has some badly molested fittings, that I hope I can at least remove at the master.
I plan on replacing it with a braided line, so I need to know the thread and fitting info for the fittings, and a length if any one knows it.
Thanks for the help!
Old 12-04-2009, 11:29 AM
HAI-TEK7's Avatar
M10X1.0, same as the common metric thread for brake lines. i had to make an extension for my slave and I bought one of those pre-made 20" hard brake lines at autozone, fit fine.
hope that helps.
Old 12-04-2009, 12:43 PM
broncbob's Avatar
Perfect man! Thanks!
the1998sr5
15
07-14-2020 08:35 PM
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
HookahRoo
07-20-2015 07:06 PM
1996Taco
07-20-2015 12:02 AM
Quick Reply: Thread info for clutch master and slave cylinder
