Thoughts wanted on 1" body lift and 31's
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
I was down in So Cal for 3 months, taking care of business, and while down there I ordered a 1" bodylift from 4Crawler. Now I get home, and looking at my BEAST, I start wondering if my rig would look funny with the 1" bodylift and my 31's. My rig is stock except for the 2" coil spacers, and my soon to be installed aisin's, if the weather will give me a day of no rain.
What do you guys think?
I'm just curious as to why you want to add the body lift. Stock suspension is more than sufficient for 31's. If you lift it more, then the tires are going to look to small. Of course I'm not a fan of body lifts.
Well, in time I will be re-gearing to 4.88's and going to 33's, at least thats what I'm saving my $$$ for. The body lift is/was a b-day gift from my sis, so no out of pocket expense for me. It's wanted for just a hint of clearance, and the 1" will only lift my overall COG 'bout .025% IIRC.
I think having a 1 inch body lift will make servicing your truck a ton easier. Things like starters and headers are easier to get at. And I think that even the oil filter will be easier to get at... I'm getting a 1.5 from 4crawler soon. Primarily to clear my 3.4 but that other stuff will be nice. especially with headers.
Both of my trucks have the RB 1" body lift.Easy for me to remove the bell housing bolts,lots of room for cleaning up of underneath the truck,removal of oil filter and doesnt require a lot of changes only need to cut out the shifter plate,front bumper bracket that you can do own your own.
31" tires will fit easily stock.
I put a 1" body lift on all my older Toyotas for underside clearance for working on everything.
It also gets sliders more centered on the frame.
My rig is stock on 31's, so I know they clear, I also that had in mind 'bout the ease of working underneath. Thanks for the pics 94runner4x4, help me to picture my rig with the lift. Thanks Wabbit and every1 for your thoughts and comments.
im telling you now, freakydeeky, that you will HATE the way it looks with the 31s...
i got the OME 901 coils on the rear and nothing done to the front and i absolutely HATE the way my tires look sooooooo small... and they are 32" M/Ts!!! they are gonna look really funky when i get the 1.5" BL... need to save up for the 33s...
Still, it doesn't look bad on your rig. Looking at yours and 94runners rigs, my BEAST will look good with the 1" bl. Now I just need it to get here. I wanna wrench on my rig. I'll be doing my manual hub swap at the same time. Thanks Abe.
I hate to tell you this, but if you've been lying to yourself 'bout the size of your tires....!____! isn't 6 inches.......
But atleast I knew you were runnin 16" rims....... Bigger packaging, smaller meat, sorry 'bout your luck, Abe
Team420
01-12-2021 04:57 PM
6th Gear
19
12-10-2019 07:31 AM
dandownunder
06-10-2002 06:18 AM
