Third member install question
I have the 22re in my 92 with the stock gears in it. Has 32x11.5s on it now, and I've been thinking of upgrading the gearing. Would 4.88s be my best choice? I've got plenty of life left on the 32s, and probably not ever go bigger than 33s. Now I try to do as much work to myself as possible, but cracking into it to replace parts seems a little out of my comfort zone, but how difficult is replacing the whole third member? Probably just the rear for now and the front later on if I can do that? Sorry if this has been asked before, but I couldnt find anything. If so just a link would be nice.
Thanks,
Jake
Thanks,
Jake
As far as what it will be used for, taking me to work, which accounts for a whole 12 miles a week. It'll occasionally see the interstate, but not much at all. I'm just trying to make it into something I can have a little fun with on the weekends, but still drive it the few miles to and from work, or other trips i need it for.
Thanks for the quick reply, I appreciate it.
When you pull the axles (rear end) don't be lazy and think it is easier to not undo the rear brake lines and rest the axle on the rear bearing seal...it will leak later..yes I learned...
4 bolts at the rear d/s, undo brake line, undo e brake ckip, 4 nuts on each axle at the backing plate, pull axles, 10 nuts on third.
Don't forget to drain the oil, chock you front wheels, use jack stands.
front axle is a little more of a PITA.
4.88 you might get lucky and find a good used factory front housing..
It is easy, just heed the warnings given above. And, the front is easier than the rear IMO. (if you pop the CV studs out backwards)
Stock 4.88s can be had for about $200 each already put together, ready to drop in. Or, go to the junkyard and look for G144 rear axle code (in the door jam).
Is there any place online that sells used ones? Or am I just gonna have to religiously check craigslist and the classifieds on this one? The best junkyard around is in Nashville, and they never seem to have more than 2 pickups/4runners at a time, and are usually completely gutted.
Or better yet, anybody have the rear for sale, or possibly both?
Used could be a crap shoot. You will pay more new but at least you should know who did the set up.
there is a used parts sources thread in the newbie tech folder.
It has a ton of links. You might get lucky and find a set from someone like Dave's off road or Jims.. shipping will be expensive..
Which vehicle is going to be to throttle sensitive? One with NO engine load at high rpms, or the one WITH engine load at high rpms. But probly not as big of a deal with a 4cyl as a v6.
I appreciate all the help yall, new to all this mess and everything helps.
Their isn't a lot of people that have any idea what type of gears are in their vehicles their parting out, so as opposed to telling every single one to check the door jam, only to find more 4.10s, which models came from the factory with 4.88s? The general consenus around here is buy 4x4, throw 6" body lift and bald 33's, then sink it in mud. Other than that nobody seems to know jack about their truck.
run 33x10.50's and 4.88's. i have 33x10.50's with 4.10 and i need 4.88's. As someone said above, 4.56's would probably be perfect for 32x11.50's, but if you're going to regear, i'd make it worth the effort, put 4.88's in, and run 33's. even 12.50's if you want a wide tire.
While its brought up, and to avoid a new thread, which coils should i be looking at for the zuk mod, preferably to avoid cutting if possible? And who makes the best spacers?
OR
Is this all irrelevant? Should I just be looking for a good lift kit? While I don't have the luxury of saying money ain't an issue, I'd rather save up and wait, than skim and regret.
Definitely makes sense. I don't need or want crazy amounts of lift, maybe 2-3", any idea as to a good source to get something along those lines? Any brands to stay away from?
2" rear lift springs would be the best. I have a 2" rear block, but i don't recommend as it interferes with the e-brake. If not wanting to spend the money for the springs, you can also get a 2" longer shackle, which is what i'm going to do soon. Can also do an add a leaf, but by far the best option is new spring. And on 33x10.50's, basically have BFGoodrich, Toyo, and Interco to choose from...kinda lengthy post sorry
jerusry
10-19-2015 05:28 PM
BeMiceElf
10-10-2015 09:40 PM
rushw
07-18-2015 01:46 PM
