Third fit
Old 02-04-2008, 06:28 AM
gonzo's Avatar
Third fit
A friend has a 96 taco. 2.7 5spd. The rear diff. pinion is shot bad. He's having it towed here.
I have rear thirds from an 88. 1 from a v6 5spd. other from a 4cyl. 5spd.
I'm not sure of his gear ratio yet but if he has 4:10 which I have will the third from one of the 88's fit the 96 rear diff.
I've done a search but not finding any info on this.
Thank you for all help
Old 02-04-2008, 06:31 AM
elripster's Avatar
You might try the Tacoma/3rd gen forums. They might know if someone here doesn't.
Frank
Old 02-04-2008, 07:56 AM
hross14's Avatar
from what i know you can swap a v-6 diff into a 4banger diff and the other way around....but look at this website and it will tell you alot
http://home.4x4wire.com/erik/diffs/#v6/turbo
Old 02-04-2008, 08:06 AM
MSR
MSR's Avatar
no taco has a 8.4 diff and hilux and 4runner has 8.0
Old 02-04-2008, 09:33 AM
hross14's Avatar
All Tacos have the BIG 8". Didnt know that...always thought the 3rd gens would have the regular 8"
Old 02-04-2008, 11:40 AM
tc
tc's Avatar
If he has an elocker, you could use the gears out of your older thirds. I guess you could install the thirdmember, but it would take some axle housing modification.
If he DOESN'T have an elocker, nothing but a Tacoma/T100 third will work.
Old 02-04-2008, 12:37 PM
gonzo's Avatar
No locker and no ABS. So I guess I'm out of luck Will have to find him one after he gets the truck here so I can see what gears it has.
Thanks guys
87SR5justin
09-29-2015 02:50 PM
4runnerFireman
09-29-2015 06:24 AM
myotherrideisayoshi
09-29-2015 05:41 AM
mtrdrms
09-26-2015 07:12 AM
anniesball
09-05-2015 08:45 AM
Quick Reply: Third fit
