Think i can run 35s??
I have 33 12.50 15 Bfg A/T's i wanna run 35 12.50 15 Bfg M/t's
I have absolutely no rub. if you look at my pictures of my truck you can see i have like three or four inches of room to my finders in my front. i know my rear can clear it.
i have a 5inch ifs lift.
I'm thinking i can clear.
with maybe a little back fender cutting when you turn completely right. or left i think it might rub if i dont cutt.
Got any ideas?
Got any ideas?
Bracket lift is usually good for 35's, as you said, with minor trimming should definitely fit.
The big unknown at this point is the offset and backspacing of the wheels.
You should be alright. Like mentioned, some rubbing and maybe you could fix by doing a little pounding/hacking. Do you have a buddy with 35's to throw on and test fit? Make sure its what you want.
Go for it just get be creative trim if you have to.
I ran 33's on my 93 4 runner stock then got a 1.5" BL did the cruiser coils and ball joint spacers.
I had enough room for 34's so 35's should be a problem in your case.
It will still look good even better in my opinon , looks like this
the1998sr5
15
07-14-2020 08:35 PM
