They all come out when it gets frigid...
...vehicle problems that is. Noticed a couple days ago I was getting a sporadic yet brief vibration from the front of my '88 4rnr. I could feel it through the gas pedal, and I only really noticed it when in 5th at cty hwy speeds. It felt like a dry metal-on-metal rub, and it disappeared as soon as it came. I drive a few miles more, listening and waiting for it to happen again, and I got to thinking about my hubs. I've had them locked in for a few months now, but haven't used 4wd in a while. I pulled over, unlocked them, and drove away without another sound, shimmy or vibration at all. Seems like that was my issue, but I'm kinda stumped on remedying it. I can't seem to clear enough snow and ice out from around my wheel/hub/axle to find it, but I could have sworn there was a grease fitting to keep the hub nice and gooped up. I know when the hub is dismantled you lather it in grease, but isn't there a zerk or fitting of some sort? Am I losing my mind? I can't find my manual, either, so any help would be ridiculously appreciated. It's fun driving in 2wd rear an hour to work in the snow, but not always
Thanks all!
-Chris
Thanks all!
-Chris
When the hubs are locked, there shouldn't be any movement between the hub and the axle end i.e. it should be like having a drive flange, ive never heard of a hub causing a shimmy. If you dont have ADD on your truck, your front driveshaft spins when your hubs are locked even when youre not in 4wd, so I would check that.
Its fine. If everything is in proper working order, leaving your hubs locked will do nothing but wear out your componats from normal usage.
Perhaps some mud/ice caused an imbalance on the cv's or d-shaft..
And no, no grease fitting on the hubs, which only require a light coating of grease Way to many people pack these things full of grease and cause problems.
